6th February 2017, 10:10
#1
Window Wipers issue
After my recent incident with the cyclist, as he went into my windshield, he has damaged the passenger wiper. It is not working , however the drivers wiper is. You can move it around and do anything, however, the drivers one is normal, wont move unless you press the stick.
Any suggestions of what it could be?
6th February 2017, 10:18
#2
Might have Sheared it off the mechanism
6th February 2017, 10:54
#3
Originally Posted by
dougie89
cheers,
I will have a look when I get home. Will I have to remove the whole cover to see it, or can I see it through the little access flap thin above the cabin filter?
6th February 2017, 12:23
#4
As dave says, it will have dropped off the joint on the arm
Sent from my iPhone using Tapatalk
6th February 2017, 14:06
#5
There is a fix in the how2 section involving using a cable tie. Not sure if you're able to view it anymore though unless you're a full member.
https://www.vectra-c.com/forum/showt...-wiper-linkage
If it doesn't work, then I Found a photo that I previously linked to.
There is also another how2 using wire to repair it.
https://www.vectra-c.com/forum/showthread.php?226914
6th February 2017, 14:54
#6
Big Dave
Brilliant cheers mate,
I gather to pull the wipers off you just pull them?
6th February 2017, 14:55
#7
Big Dave
Never mind, just googled it, a 13mm socket i think it was
6th February 2017, 21:21
#8
You can get the repair clip to fix it permanent but the cable ties work lol
7th February 2017, 11:18
#9
Martinez
Yeah, something like that, then you need to get the wiper arm off the splined shaft. It might come off easy, or some help from a screwdriver to prise it off.
7th February 2017, 15:33
#10
If you use the clip you don't have to remove the wiper assembly at all.
Sent from my iPad using Tapatalk
