Results 1 to 3 of 3
Thread: How do i remove rear window winder???
    Regular Member andyfinch's Avatar
    There Abouts
    Default How do i remove rear window winder???
    Help.....kids have broken the rear window winder so i am trying to remove it but have'nt got a clue how to.....been looking for a screw around it etc but i dont want to ****** up the door card....any ideas......cheers..
    Full Member andy.l's Avatar
    Wirral / ellesmere port
    8 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    there is a spring c clip that holds it into position so you will have to get a
    flat blade screwdriver and push it right behind the winder handle were it fits
    to the regulator then just prise upt very slightly so you can see behind the
    winder handle then the c clip shud be seen and use another flat blade
    screwdriver to push the clip to 1 side then the handle shud pull off the
    regulator spline,if no luchk then let us know and i`ll try get piccys in more
    detail.
    2011 insignia elite tourer 2.0 cdti 160 manual,silver
    ^^^.. just as he said...orthere are very cheap window winder clip removal tools available for a few pounds
  1. How do I remove chrome window strips?
    By CBak109 in forum Styling
    Last Post: 25th September 2012, 14:08
  2. How 2 Remove Elec Window Switch N/S
    By robdd1 in forum Vectra C / Signum Car Chat
    Last Post: 19th August 2009, 21:24
  3. how to remove vlack window sills
    By damadom in forum Styling
    Last Post: 27th May 2009, 17:24
vectra c rear window removal
remove window winder vectra c
how to remove vauxhall 2011 window winder
vectra c window winder removal
how to remove window handle vectra c
how to remove window hanble vectra c
Remove window winder handle from vauxhall vectra rear door
