Thread: Rattle from engine bay
    EDINBURGH
    Default Rattle from engine bay
    vectra c 2003 2.0 DTI 53000 on clock
    first post and hoping for some help
    engine at idle no rattle
    when revs increase rattle starts (some might describe it as a tick tock sort of noise)
    seems to be coming from behind the wheel arch cover on drivers side front wheel, its not got any louder over the past few months, thinking its one of the pulleys
    Also is it a big job to change drive belt
    thanks in advanced
    kenny
    it's not at all a big job to change the belt, and you might want to investigate very quickly.. the DTi has a hhabit of throwing off it's bottom 'pulley' as the crank damper assembly delaminates, leading to loss of the drivebelt and possible damage to the end of the crank..if i was a betting man, i'd say the rubber has delaminated and you need a new bottom pulley..
    EDINBURGH
    pulley looks fine, no sign of any parting of ways between damper and pulley
    gave all the pulleys, alternator etc a coating of wd40 with engine runing to see if noise would go away but that had no effect.
    EDINBURGH
    was changing the oil today so had a good look about, found that the rubber on the pulley was very soft and i could easily move it and thats when i found that the plastic backplate bit of pulley was loose and easy to get my finger between it and the metal of the pulley soi assume i need a new pulley?
    Regular Member m_r_shaw's Avatar
    Sunny Waterloo, just outside Liverpool.....
    looks like it.
    EDINBURGH
    anyone know the cost of a replacement pulley
    kenny
    as GSi3.2 says, this seems a very common problem, so it does need to be checked out mate
    EDINBURGH
    thanks for the replies, off to search web to find cheapest
    Good luck Ken
  1. Engine rattle
    By chillin_man in forum Engine & Drivetrain
    Last Post: 1st November 2013, 09:56
  2. Engine cover rattle and engine cough
    By Hursty103 in forum Engine & Drivetrain
    Last Post: 15th May 2012, 12:22
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. engine rattle
    By paul wingnut in forum Engine & Drivetrain
    Last Post: 11th July 2009, 13:42
  5. Engine rattle
    By mr.4dil in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2008, 14:32
