Results 1 to 10 of 11
Thread: Vectra SRi CDTi Service Costs + Tyres
    Ilkeston
    Default Vectra SRi CDTi Service Costs + Tyres
    Can anyone help me out with servicing costs on a Vectra SRi 1.9 CDTi?
    It will be new and expect to do between 30-35k a year.
    I know the regime is every 20k, but what is the cost for a main dealer 20K, 40K, 60K, 80k, 100k and 120k service?
    I'm also having the 19" snowflakes and how much average is a set of 19's to boot?
    Dave
    Chester
    Had the 20K service this week. £168.
    As above matey. £168.00
    A 235/35/19 tyre (for a half decent one) should cost you about £130 upwards.
    Regular Member fellie's Avatar
    Lincoln
    Charles Warner are doing me an oil and filter ( full synth 5w30 ) tomorrow for £76 inclusive ..
    what do they actaully do for the extra £112 ?
    Quote Originally Posted by fellie View Post
    Indicators, lights, signalling devices and airbags - check visually
    Batteries, remote control - replace
    Windscreen Wipers, windscreen wash, hamplamp wash system - check & correct
    Coolant level, antifreeze - check & correct
    Brake fluid level - check & correct
    Battery Terminals - Check
    Pollen filter - replace
    Air cleaner element - replace
    Timing belt visual check - change at 10 years or 100,000 miles
    Valve clearance - check & adjust
    Power Steering - check for leaks & correct if necessary
    Engine Oil - change
    Fuel Filter - drain water
    Parking brake - check & adjust
    Check bodywork for corrosion warranty
    Wheel brakes - check visually
    Auto transmission - change oil
    Level control system - check
    Steering rack, track rods - check visually
    Brake fliud - change
    Wheel attachment - check and torque bolts
    Headlamp aiming - check & correct
    Lubricate door hinges
    Test drive & final inspection
    I've probably missed something, but that's the main checks I think.
    Lincoln
    hmm, better than a lot of other dealers servicings then..
    they really check valve clearances every 20 k ?
    I might ask what the Charles Warner group do for the money , 70k on the clock, a little tlc wouldnt hurt .. ( it was serviced last week before I bought it, no idea what oil though , hence my oil / filter booking )
    90% of the list can be done yourself in minutes, but brake fluid, headlamp align, fuel filter drain and valve clearances is well worth £112 imo
    and to think, I just spent £10 on a new pollen filter today .. Im sure they'll deduct that !!
    oh, its a real bargain look, only £96 more.. dodgy maths lol
    Feb 2007
    Midlands
    Default cae2020
    If your running 19's be careful with the tyres I am running conti's on my VXR and have just had to have 2 new tyres on the front cost was £480 they are very very difficult to get hold of
    Ilkeston
    Thanks for the info, what does the 40k and 60k service at main delaer cost?
    I'm guessing 60k is camblet so is the most expensive and this would be done again at 120k?
    Are the extra ones in between just normal £168 ones?
    Dave
    Lincoln
    £202 inclusive..
    that was for the '2 year ' servicing using 5w30 full synth and a brake fluid change. ( £25 which is a bargain imo )
    would have been + £10 for the pollen filter, but as mentioned I did that yesterday
    the tech mentioned he had to look twice at the mileage .. only the worn seat bolster giving it away he said
    and my oh my what a difference, I dont know if its the oil, or new software ( I checked they had updated it ), but its so hard to tell its a diesel now ..
    Quote Originally Posted by HA54SYM View Post
    A cambelt interval is 10 years or 100,000 miles on the 1.9 diesels matey.
  1. Service Costs on Vectra Life 2005
    By mishmos in forum Troubleshooting
    Last Post: 8th September 2011, 09:44
  2. service costs
    By elite56 in forum Vectra C / Signum Car Chat
    Last Post: 9th September 2007, 22:38
  3. Vectra SRi 1.9 CDTi Service Costs + Tyres????
    By HA54SYM in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2007, 18:27
  4. 2nd service costs...
    By Dwabo in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2006, 19:04
diesel fuel filter drain vauxhall vectra 120 site:www.vectra-c.com
