Thanks Thanks:  2
Likes Likes:  4
Thread: Fitting rear pads/disks..
    Regular Member megsdad's Avatar
    May 2011
    Northwich, Cheshire..
    11 Post(s)
    Vehicle : SRi Estate Nav
    Trim : Boring cloth
    Engine : CDTi 150
    Default Fitting rear pads/disks..
    Going to be replacing rear disks and pads in the coming weeks, got everything i need i think....
    just wondering is the handbrake adjustment fully automatic or do i need to reset something, do i wind the pistons fully in or just enough to allow the pads to fit.
    Cheers for any advice..
    Steve
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    Handbrake is automatic just pump the pedal a few times first before using handbrake. They will most probably have to go fully in to allow the pads to fit.
    edit: undo ressvior and rewind them back nice and slow.
    edit no 2: May as well clean up the slider pins also.
  3. Thanks megsdad thanked for this post
  4. #3
    Midlands - Head case Organiser Dog_Book's Avatar
    Oct 2013
    Derby
    166 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    There might be a how2 as the handbrake needs to be reset first before pumping the pedal then operating it.
    Teapot Tuned 260/300
    https://www.vectra-c.com/forum/calendar.php
  5. Likes megsdad, Big Dave liked this post
  6. #4
    May 2011
    11 Post(s)
    Trim : Boring cloth
    Engine : CDTi 150
    Quote Originally Posted by Dog_Book View Post
    First thing i did was looked through the how2's but didn't spot anything specific, posts on bleeding the system and caliper refurb, I didn't see one about handbrake reset though..
    I initially thought it would be straight forward and wind in the pistons, you've got me doubting myself now.... !!
    I'll go and have another look down the how2 lists or on youtube.
  7. #5
    rothwell leeds
    Vehicle : vectra c
    Trim : sri
    Engine : 1800 vvt
    Remove the reservoir cap then remove the slide pins that hold the caliper on take the slide rubbers out of the calipers and cleaning corrosion out of the holes with either a round file or a drill bit... when clean put the rubbers back in using a bit of Fairy liquid...Next wind the calipers fully back..I usually spray some 3 in one oil under the dust cover helps to keep things moving,next wire brush the carrier's down bit of copper grease on pads and build back up using engine oil on the slide pins not copper grease.. reservoir cap back on, start car pump brakes back up,then handbrake on &off about 10 times,you will find the hand brake gets better over the next week or so....
  8. Likes megsdad liked this post
  9. #6
    May 2011
    11 Post(s)
    Trim : Boring cloth
    Engine : CDTi 150
    Thanks for the advice and comments...MOT in Feb so needs to be done.
    This clip looks to be the job in question.. https://www.youtube.com/watch?v=2VV-XFsyQqg
    Cheers Steve
  10. #7
    Full Member Woody's Avatar
    May 2012
    North West (Warrington)
    168 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    I'm assuming that this is the "How2" mentioned ?
    https://www.vectra-c.com/forum/showt...ear+brake+pads
    Hope that helps Steve and good luck mate
    Woody
    Woody's Vx Ice Addons UK/Eire Distributor of the Comfort Unit and Video Accessories from www.PepaS.cz Designed to enhance your Headunit & Display these add in Additional Data and Reversing Camera & Media. NOW INCLUDES FULL Vxr/OPC NEEDLE SWEEP & LIGHTS Also CD70 Aux In & 3 Line Display Updates.
  11. Likes Big Dave liked this post
  12. #8
    rothwell leeds
    Vehicle : vectra c
    Trim : sri
    Engine : 1800 vvt
    That's it mate,but talk about messing about,,and believe me those E18 bolts don't come off as easy as that!!!lol
  13. #9
    May 2011
    11 Post(s)
    Trim : Boring cloth
    Engine : CDTi 150
    Quote Originally Posted by big tee View Post
    Must admit he does some faffing about...lol
  14. #10
    May 2011
    11 Post(s)
    Trim : Boring cloth
    Engine : CDTi 150
    Quote Originally Posted by Woody View Post
    Woody
    Cheers @Woody ...I did look but never spotted that one, hence my wee shout out.
    Blind as a bat.
    Thanks...
  15. Thanks Woody thanked for this post
  1. Rear Pagid break pads not the same fitting
    By cermi in forum Suspension, Wheels & Brakes
    Last Post: 10th July 2016, 20:33
  2. For Sale: VXR rear Brake set up including HEL brake hoses and new disks and pads
    By merikiito in forum Parts for sale
    Last Post: 11th May 2014, 13:51
  3. For Sale: Mtec 288mm dimpled and grooved front and rear disks and pads
    By s4ddys in forum Parts for sale
    Last Post: 17th November 2013, 17:46
  4. Rear disks and pads
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2007, 19:05
https:www.vectra-c.comforumshowthread.php228523-Fitting-rear-pads-disks&goto=newpost
