Thread: Tailgate removal estate
    Mar 2014
    aberchirder
    Trim : Sri
    Engine : 2.2 direct
    Default Tailgate removal estate
    Hi folks,
    Need some help, removing the tailgate to swap for a new undamaged one a 04 Vectra c pre-facelift couple of questions.
    1-Should I remove the wiring loom from the tailgate out or from the car out?
    2- I notice the rear window washer pipe goes through alongside all the electrics in the main loom, where should I disconnect this is it at the back of the nozzle or somewhere else?
    Any help gratefully received
    Administrator plasma's Avatar
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    leave wiring in tailgate itself if same type, ie not electric tailgate.
    follow wiring through from boot along back of headlining down to the REC (rear fuse box)... unplug connector... then from the connector remove the two indivdual plugs from the larger connector, this will then allow it to come out from inside the car and out of the hole by the rubber boot/grommet at the top near the hinge...
    there is a connector nozzle just a little way inside further along on the passenger side.. just untwist the pipe off of it.
    Full Member sri cliff's Avatar
    Sep 2015
    lincoln
    8 Post(s)
    Vehicle : vectra estate
    Trim : sri
    Engine : 1.9cdti
    As plasma said I did this recently and went on really easy, you'll need an extra set of hands once you come to remove the lid. The boot struts just clip off and back on again you'll see the clip at the top.
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    once the struts are off, the tailgate get pretty heavy
  1. Tailgate , removal ?
    By biffbangpow in forum Bodywork & Interior
    Last Post: 2nd November 2012, 18:50
  2. Tailgate strut removal?
    By rushy in forum Bodywork & Interior
    Last Post: 9th December 2011, 09:19
  3. Tailgate removal ??
    By MID LIFE CRISIS in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2010, 21:14
  4. tailgate removal vectra c
    By marts cdti in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2008, 23:45
  5. Estate tailgate interior trim removal
    By parapaul in forum Bodywork & Interior
    Last Post: 27th December 2006, 14:24
