Results 1 to 10 of 14
Thread: 3.0 CDTI being weird
    Dec 2016
    Hertfordshire
    Engine : 3.0
    Year : 56
    Default 3.0 CDTI being weird
    Second signum Ive had, this one being a 56 plate 3.0 cdti with 70k on the clock, picked it up early December.
    Its been great, but is now playing up and endless searches on the forum are sending me on many paths, so im hoping for some pointers, any how 2 guides and any recommendations for somewhere local to Hertford to help out if necessary.
    Ok, so on a 300 mile drive back from up north on NYD car was doing absolutely fine, then 50 miles from home, a slight hesitation, but back to usual after that. next day, more hesitation, and a lumpy idle occasionally, including the change from 0.2g/h to 0.9g/h.
    Then a few days ago, big power loss when accelerating, then the eml came on, went into limp home mode. turned off, restarted, no light and car running perfectly. its now running rough more than running well, but certainly seems to have been a gradual decline to now running weird. occasionally revs at idle raise from 700 to 1kish
    No reader at the moment (in the middle of moving house, great timing), but brake test gives codes P0001 and P0235.
    I've had a quick scope around and no obvious splits in hosing, but will head out with a torch later.
    Advice on where to start, happy to do jobs myself but time is a limit.
    thanks for the advice already from the many posts I've searched, and for any pointers from this post,
    Ant
    South West - Assistant RO
    Mar 2015
    Bristol
    14 Post(s)
    Engine : 3.0 V6 CDTI
    0.9 was a DPF regen and you loss a little bit of power and can get lumpy running - the other sounds like a scv type issue however this can be down to a fuel filter needing to be changed or the strainer in the fuel tank
    Mar 2015
    Bristol
    14 Post(s)
    Also the most common pipe to split is the hard and silicon ones leading to the TB
    Dec 2016
    Hertfordshire
    Engine : 3.0
    Year : 56
    Cool thanks Dave, first diesel so not familiar with this regen stuff, I'm assuming it shouldn't be doing it on every trip after 5 minutes or so though? is there a way to check the dpf, is it an exhaust off job (i hate those)
    Mar 2015
    Bristol
    14 Post(s)
    If it needs to do it it will try repeatedly till its done failure to complete canblock DPF. Take on the Motorway keep above 2.5k rpm when its at operating temp for 20-30 mins and see if that helps. Fuel filter chanege would be a good start especially if you you dont know when it was last done. Just be carefull these are not self priming
    Dec 2016
    Hertfordshire
    Engine : 3.0
    Year : 56
    Cool, will get the fuel filter changed.
    So ive just taken it for a run with EGR disconnected, seemed to run much better with no idling issues, only a short run
    also, and perhaps more importantly, I read the code wrong, the p0001 code is P0093, hopefully its a fuel filter over scv's....
    im trying to find a part number for z z30dt fuel filter if anyone can beat me to it!
    Mar 2015
    Bristol
    14 Post(s)
    do not run it for long with teh EGR disconnected will stop it regen'ing and will cause a host of issues
    ECP - 503880047
    Mar 2015
    Bristol
    14 Post(s)
    Make sure you fill the canister up with fuel when you replace it that should stop the airlock
    Dec 2016
    Hertfordshire
    Engine : 3.0
    Year : 56
    Thanks Dave, will get back tomorrow when I have a go.
    Midlands - Head case Organiser Dog_Book's Avatar
    Oct 2013
    Derby
    182 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    I would start looking in here instead https://www.vectra-c.com/forum/forum...Z30DT-Specific
    Teapot Tuned 245/300
    https://www.vectra-c.com/forum/calendar.php
  1. Weird dtc 06 cdti 120 bhp.
    By ianwat23 in forum Engine & Drivetrain
    Last Post: 10th August 2015, 01:46
  2. 1.9 CDTi Not Starting....... Really weird please read...
    By Adz in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2015, 03:06
  3. Weird Vibration CDTi 150
    By guvnagra in forum Engine & Drivetrain
    Last Post: 15th November 2012, 11:24
  4. Just Weird!
    By si_hoss in forum Vectra C / Signum Car Chat
    Last Post: 7th July 2010, 14:11
  5. Weird noise from Signum CDTI 1.9 CDTI (150)
    By oneightycd in forum Diesel Engine related
    Last Post: 22nd June 2007, 22:27
