Likes Likes:  2
Thread: F40 Gearbox Oil
    Regular Member OllyXP150's Avatar
    Jun 2015
    Sheffield
    Vehicle : Vectra C Hatchback
    Trim : Sri 1.9 Cdti 150 Nav XP Pannacotta
    Mileage : 98k
    Default F40 Gearbox Oil
    Hey chaps. Anyone recommend a quality gearbox oil for the f40 box, other than GM? Changed the oil just over a year ago with the red GM stuff from Vauxhall, but very soon going to be changing the clutch and flywheel. Just wondering if theres anything better, or to stick with genuine. TIA
    Full Member ROCKATANSKY's Avatar
    Apr 2008
    suffolk
    I think the general con census is GM is fine with the revised 2.4 ltrs
    Sent from my iPhone using Tapatalk
  3. Likes OllyXP150 liked this post
  4. #3
    Wales
    When my clutch was done recently, I used “GL5 FUCHS TITAN SINTOFLUID Synthetic Transmission Oil Fluid 75W-80 3 Litre” instead of VX stuff. I was amazed at how much smoother the box was. Cheaper too.
  5. Likes OllyXP150 liked this post
  6. #4
    Jun 2015
    Sheffield
    Mileage : 98k
    Just been doing some research and found you shouldn't use gl5 in a gl4 box! Apparently the extra chemicals/additives in the gl5 can strip the brass coating off the syncros. The red GM oil is made by Castrol, and is 75/85 synthetic gl4. So guna play it safe and stick with that. Cheers anyway
  1. M32 gearbox can`t get gear selector back in gearbox HELP!
    By v33tra in forum Engine & Drivetrain
    Last Post: 30th March 2017, 07:43
  2. Gearbox and Gearbox Oil question
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2011, 17:01
