Looking very nice mate
- Fitted the Hansen styling DRL/Fogs, using proper conduit for a neat install. Set them to stay on even when the main lights are on and used a bullet connector so it can revert back to correct function if needed for MOT. Just need to find the right wire under the UEC for the ignition on live to activate them later, currently in fuse 10 for AFL's. The fog trigger wires go n/s side down and around n/s fog to the body loom, the ign on wire and earth follow the wiring for PP and the temp sensor down the back up into the battery/UEC area to keep it neat. http://www.hansen-styling-parts.de/e...ducts/1847-O-1
- Replaced LED side lights with whiter ones from http://www.ebay.co.uk/itm/2518662697...%3AMEBIDX%3AIT as this seller sells proper white ones most of the time as i don't like the blue tinted ones.
- Soldered a fly lead bulb holder to the passenger sidelight as the error came back even with the canbus LEDS.
- Fitted new headlight mounts as a couple were worn from over use.
- Updated the CD70 with dealer disc.
- stabbed my finger with the stanley blade while cutting back some of the wiring
IMG_3979.jpgIMG_3980.jpgIMG_3981.jpgIMG_3982.jpgIMG_3983.jpgIMG_3985.jpgIMG_3991.jpgIMG_3992.jpgIMG_3993.jpgIMG_3997.jpgIMG_3998.jpgIMG_4002.jpg
Teapot Tuned 255/300
Tech2 & MDI diagnostics + SPS
Its not been a worth while job unless you've lost a finger or stabbed yourself with a stanley knife.
- Phone cradle removed and drinks holder fitted.
+ picture of dimming mirror
List of things to do and just done-
- de-badge front wings DONE
- clean out scuttle and drains DONE
- replace the heated washer jets
- new pollen filter DONE
- check K&N and replace with genuine air filter
- clean MAF
- auto lights/wipers set up with correct screen and sun strip
- dimming mirrors all round in conjunction with memory mirrors PARTLY DONE
- heated front seats/full leather swap
- replace all headlight bulbs for chrome and Ring +%120 lamps DONE
- replace both outer CV joints with genuine and all new boots all round for future protection
- refurb alloys
- fit factory tinted windows
- touch up minor paint issues
- remap to 220 off and 300 on
- possibly sell the private plate DONE
- JL audio speakers all round again, components
- LED's all round PARTLY DONE
- footwell lights front and back
- replace navi aerial seal
- replace o/s brake duct
- LED drl or dual type for front fogs DONE
- dual rear fogs mod
Car is looking Fantastic Steve.... Looking forward to seeing it next week
Hasnt it bankrupted you yet with its amazing appetite for juice haha
- Removed and cleaned K&N air filter then re-oiled, discovered the hard inlet pipe isnt well fitting and very close to the MAF making it near impossible to remove the airbox top. Also due to lack of space the rubber boot has been damaged but still seals. This has created another job to cut the pipe down which will be done at a friends with a proper saw machine.
- MAF removed and cleaned.
- 3 more 9 SMD led panels installed, footwells next.
IMG_4037.jpgIMG_4038.jpgIMG_4039.jpgIMG_4050.jpgIMG_4051.jpgIMG_4057.jpgIMG_4042.jpgIMG_4043.jpgIMG_4045.jpg
I like what you are doing with the VXR.
Paul
