dont change the air filter the standard ones are too restrictive. just clean and reoil the k&n one, make sure you dont over oil it as it can affect the maf.
Got some filter cleaner and spray in the shed from when i used to race motorbikes, might give it a go and clean the MAF while im at it.
Teapot Tuned 255/300
Tech2 & MDI diagnostics + SPS
- Indicators sorted, the housing had worn away possibly though arching and damaged the bulb holder to, filled the solder down to make it smooth for the holder to turn easily in the housing.
- Fitted Ring Xenon ultra +%120 lamps all round the front and chrome Orsram indicator lamps and LED sides which need swapping to whiter ones as i put new halogen blue ones but the colour was still a little yellow compared to the HIDs.
- Cleaned the engine bay pics to follow in daylight.
- Replaced the very clogged pollen filter with a new carbon activated one but put in the right way round this time lol.
- Cleaned and scrubbed the scuttle area as much as i could without removing the panel.
- Put LEDs in the rear number plate fittings.
- Genuine rubber mats fitted all round.
IMG_3885.jpgIMG_3905.jpgIMG_3912.jpgIMG_3913.jpgIMG_3916.jpgIMG_3919.jpgIMG_3920.jpgIMG_3921.jpgIMG_3924.jpgIMG_3925.jpg
Broken slats repaired.
So that's two VXR estates in the local Derby/Notts area and there was me thinking I have something rare Still not happy with the rear height so it's being sorted next month and I'm awaiting a delivery from Germany. I've got two vents I need to remove and fix, looks easy enough to sort.
standard issue on the afls with the turn signals
- Rear number plate fitted, did front yesterday while busy at work.
- SMD panels turned up so started first on the rear interior lights.
- Finished off tweaking tail pipe positions as they were set right in for some reason.
- Took delivery of flex organiser as new owner of my previous estate stole it on Tuesday
- Fitted dimming mirror and surround, waiting for loom now.
- Took outer light clusters out and cleaned contacts, replaced lamps for longlife and chrome indicators. The rear lamps were about to pop anyhow.
IMG_3951.jpgIMG_3952.jpgIMG_3955.jpgIMG_3957.jpgIMG_3958.jpgIMG_3959.jpgIMG_3960.jpgIMG_3961.jpgIMG_3964.jpgIMG_3965.jpgIMG_3966.jpgIMG_3967.jpg
Good work sir. Just realised your plate is a little similar to mine, must have been separated at birth.
VE07 WOJ - yours
VE07 WLZ - mine
Very nice motor Steve
