Thanks Thanks:  18
Likes Likes:  579
Page 46 of 47 FirstFirst ... 3644454647 LastLast
Results 451 to 460 of 462
Thread: Dog_Book's VXR estate
  1. #451
    Oct 2013
    Derby
    309 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    • Bedding the new front brakes in seemed odd, so after some advice pads removed, cleaned with brake cleaner and sanded down to clean up faces with 80 grit emery on a sander. Worked really well. Pads are EBC blue which still after time do not have great cold bite, these are being exchanged later for EBC Yellowstuff as the closest to a road pad before spending double on DS2500 pads. The Blues will be kept for any possible track days. https://www.carparts4less.co.uk/search/93072053Y
    • Previously found incorrectly routed loom to hub rerouted.
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
  2. #452
    Oct 2013
    Derby
    309 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    • Oil and filter change with usual engine flush, 2500 miles since last change. On the 2nd service book now.
    • Used my trusty @ST200 TM tool to stop oil going all over the heat exchanger and catch the oil filter housing cap as its still going strong.
    • Spare K&N filter clean and re-oil, dishwasher has cleaned it up really well but opened some small section up through the cotton.
  3. Likes watchman liked this post
  4. #453
    Regular Member ST200's Avatar
    Feb 2011
    Near Ikea M1 J26
    12 Post(s)
    Trim : VXR
    Engine : Z28NET
    Been waiting for you to finally update your diary, they look AWESOME now they are on. Great work sir
  5. Likes Dog_Book liked this post
  6. #454
    Oct 2013
    Derby
    309 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Quote Originally Posted by ST200 View Post
    Easier to do now i have a working PC again, got all rear brake parts waiting to show once they are fitted and info on gearstick leathers. Just waiting for https://www.inspireautomotive.co.uk/ to get back to me as Ive got a darker black for the actual gear knob to match factory but only a small amount as companies only usually sell as whole hides
  7. #455
    Apr 2016
    Ipswich
    58 Post(s)
    Vehicle : Vectra C
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Year : 2003
    Mileage : 140000
    I spot some shocks that need tlc.... you are slacking
  8. #456
    Oct 2013
    Derby
    309 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    You can go sit on a cucumber if you think im removing the rust on them then repainting them only to rust through again. If i did everything with some rust on underneath it would be an unachievable nightmare.
  9. #457
    Oct 2013
    Derby
    309 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    IMG_7129.jpgIMG_7130.jpgIMG_7131.jpgIMG_7132.jpgIMG_7133.jpgIMG_7134.jpgIMG_7135.jpgIMG_7136.jpg
  10. #458
    Apr 2016
    Ipswich
    58 Post(s)
    Vehicle : Vectra C
    Year : 2003
    Mileage : 140000
    No thanks! I'm not into that...you are welcome to the honours but hey you even painted the bolts to the calipers yellow! So could've touched up the rusty bits while you were at it... slacker!
    Sorry couldn't resist.. but now that seed is planted you probably will replace them for better i spotted you asking about the difference between b6 and b8
  11. #459
    Oct 2013
    Derby
    309 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    • Rear calipers, carriers, discs and pads fitted.
    • Calipers are Remy refurb blasted and painted with only the outer side cleaned up smooth all other marking left on, carriers are blasted and painted. Meyle kit for caliper slides and boots, GM outer spring. Discs are high quality Zimmermann drilled with Z coating 430.1496.52 , this was removed during the tuftriding process which is a DBtm process that stops rust forming and protects the disc from warping. Genuine GM pads were used as the offer the best performance all round as they are high quality. For track use front and rear pads would have to be swapped if i got good due to the increase in temps.
    • Whilst all apart handbrake cable lubed with it lifted up so the oil would go down the cable sheath and all rubber parts lubed with red rubber grease including the handbrake cable end which was the worst part of this job removing it from the place its been for about 13 years. It wont seize in place now with the fresh painted calipers along with grease in the fitting.
    • https://web.tecalliance.net/otto-zim...peNumber:23276
    IMG_5348.jpgIMG_5350.jpgIMG_5351.jpgIMG_5360.jpgIMG_5361.jpgIMG_5362.jpgIMG_5363.jpgIMG_5886.jpgIMG_5887.jpgIMG_7139.jpgIMG_7143.jpgIMG_7144.jpgIMG_7140.jpgIMG_7141.jpgIMG_7142.jpgIMG_7149.jpgIMG_7150.jpgIMG_7151.jpgIMG_7145.jpgIMG_7146.jpgIMG_7147.jpgIMG_7152.jpgIMG_7154.jpg
  12. Likes northpole, GSiFan liked this post
  13. #460
    Feb 2011
    Near Ikea M1 J26
    12 Post(s)
    Trim : VXR
    Engine : Z28NET
    All you need now are black wheels & it'll look like a bumble bee is trapped
    Splendid work as always.
  14. Likes northpole liked this post
  1. Day with Dog_Book
    By strothow in forum Quick Photo Album
    Last Post: 18th October 2014, 00:57
  2. The Dog_Book
    By Dog_Book in forum Introduce yourself.
    Last Post: 15th October 2013, 23:16
vauxhall 24435372
https:www.vectra-c.comforumshowthread.php228315-Dog_Book-s-VXR-estate&goto=newpost
