11th February 2019, 20:32
#291
Originally Posted by
sinbrad
I'll be keeping an eye on this and may have to dip into an upgraded map?
Depends on what boost yours is running now? Ive been slack and not ran many tests on ours (the 2.8 R&D mapping project), need to take the car out with a couple of logging tools really and go from there.
The objective of the mapping project was to alter the off sports available power and how it was delivered or be able to alter it to however a person wanted as you can have full power off/on but with a nice gentle delivery as above.
The big boys dont seem to like offering this and even if they did they wouldn't test and test over like i have, by then they probably have more programs to alter maps in one go unlike me going in bit by bit.
Teapot Tuned 255/300
Tech2 & MDI diagnostics + SPS
1st March 2019, 23:25
#292
1st March 2019, 23:39
#293
The Saab website link doesn't work but the Ebay one is spot on and the seller lives not too far away
14th March 2019, 20:48
#294
- Fitted a new genuine OS rear tailgate strut to help it stop stopping on its way up. Supplied from GPS on eBay for £20! Although the one coming off i cant move but then i can't replicate the forces involved so If its still stiff when cold after this ill do the NS which should be a lot easier. Basically its about taking the clips off and pulling up and out with twisting of the cable base and again at the top and keep hold of the top bit as the cable wants to pull it self back in and its very strong. The system just works on a pull so the 2 struts push it open with the motor controlling it up and then pulling it back down to shut. A prop for the tailgate was needed as the remaining strut could not hold it all. Once propped all the work can be done from there until its refitted.
IMG_3932.jpgIMG_3933.jpgIMG_3934.jpgIMG_3935.jpgIMG_3937.jpgIMG_3938.jpgIMG_3939.jpgIMG_3941.jpgIMG_3943.jpgIMG_3945.jpgIMG_3947.jpgIMG_3948.jpg
Post Thanks / Like - 0 Thanks, 7 Likes
16th March 2019, 17:56
#295
Just been PM-ing you about paints jobs on VXRonline.Gotta say top job and epic read.
23rd March 2019, 15:29
#296
- Fitted a new NS tailgate strut for the power system as the OS one didn't really help. I did not that the new NS strut couldn't be compressed by my overweight body but the old one once off could. Bought from GPS again through eBay which they seem to like for cheap deals The NS is easy to do just pop the clips back and it comes off with ease, i did prop the tailgate but found the remaining strut held the tail up easily and i could move it about up and down if needed. Yet the other week the NS strut could not hold it up at all which i nearly had an estate boot buried in my head Of course i cleaned up the ball joints and surrounding area before fitting the not strut. Does open smoother so this should be the missing link in stopping it from jamming at the bottom when opening as there is no other part of the system which pushes the tailgate up and open.
IMG_3977.jpgIMG_3978.jpgIMG_3979.jpgIMG_3980.jpgIMG_3981.jpgIMG_3982.jpgIMG_3983.jpgIMG_3984.jpg
23rd March 2019, 16:19
#297
Is the actuator playing up ?
Lao liked this post
30th March 2019, 14:03
#298
Dog_Book
Just curious about Part Number 9156812. Do you have a traditional disc shield or just these brackets? I will have to check mine to see what I have installed as I think this is OPC/VXR only
30th March 2019, 15:29
#299
Simon_Fuller
It’s on a few models not just vxr have a-look on eBay for complete hubs with bearings.
30th March 2019, 15:32
#300
Jon1796
Fair enough on the parts system shows Opc/Vxr so got me wondering. The hubs are standard apart from ids/non ids models.
