Thanks Thanks:  14
Likes Likes:  430
Page 35 of 35 FirstFirst ... 25333435
Results 341 to 350 of 350
Thread: Dog_Book's VXR estate
  1. #341
    May 2012
    North West (Warrington)
    203 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    Quote Originally Posted by Lupus View Post
    Why you selling mats and rear console ?
    Is he ?
    Woody's Vx Ice Addons UK/Eire Distributor of the Comfort Unit and Video Accessories from www.PepaS.cz Designed to enhance your Headunit & Display these add in Additional Data and Reversing Camera & Media. NOW INCLUDES FULL Vxr/OPC NEEDLE SWEEP & LIGHTS Also CD70 Aux In & 3 Line Display Updates.
  2. #342
    Jan 2008
    113 Post(s)
    Vehicle : .....
    Trim : .....
    Engine : .....
    Year : .....
    Mileage : .......
    He's not selling........theyre Free to the first person who offers him a certain large green vegetable.
  3. Likes Lao liked this post
  4. #343
    Oct 2013
    Derby
    258 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Quote Originally Posted by RBH View Post
    There’s enough on here for me to choose from
    Teapot Tuned 245/300
  5. Likes RBH liked this post
  6. #344
    Full Member JOHNBOY's Avatar
    Wherever ever I lay my Head
    15 Post(s)
    Trim : SRI XP1
    Engine : 1.9 CDTI 150
    Wonder what that could be ??? I was going to suggest that he’s fond of the odd cucumber but you said vegetable...
  7. Likes RBH liked this post
  8. #345
    Oct 2013
    Derby
    258 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
  9. Likes Jon1796, RBH liked this post
  10. #346
    Oct 2013
    Derby
    258 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    • Smaller resistors so i can rework the side light led anti-error and flash circuit without using a halogen lamp with alloy tape over it. Will test on a spare battery first see how hot the get along side a led lamp. I did try but reading between the lines i think i got it with some valuable info from the overly clever @Z80 well like i said i have never learnt electronic maths mines in engineering.
  11. Likes Lao liked this post
  12. #347
    Oct 2013
    Derby
    258 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    • Tried the 50w versions as they are very cheap and yes they run cooler than the 25w ones and were tested at 14.1v so closer to normal running in the car so ill be fitting these next time the bumper comes off.
  13. Likes RBH, northpole liked this post
  14. #348
    Oct 2013
    Derby
    258 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    • Fitted the newly sourced 50w 82ohm resistors to the side light circuit to stop errors and stay cooler than the previously fitted 5w halogen lamps. This set up is the perfect solution for anti strobe and error for using LED sides. Thanks again to @Z80 for confirming my selection would work as the electronic maths is too much for my VXR owners brain to compute. This gives no errors when the lights are off, no strobing, no overly hot temperatures from the parts and no errors when turning them on or off and no melted parts as can be seen from the pictures of the lamp holder disintegrating. This is all tucked away with plenty of air gap around it all under the headlight internals as before. You could use the even smaller 25w 82ohm resistor as this emits still less heat than the 5w halogen lamp but i wanted as cool as possible with as small as resistor as possible and as you can see the 50w version has loads of room to go inside the headlight and i think any bigger the dimensions increase in height which would have started to cause fitting issues. One of the 5 year warranty LED's had failed so swapped them both for return swap. Also employed the Dog_BookTM method for dropping the bumper quickly for easy access to the headlights rather than having to pull the whole lot off.
    IMG_4298.jpgIMG_4299.jpgIMG_4300.jpgIMG_4301.jpgIMG_4302.jpgIMG_4304.jpgIMG_4305.jpgIMG_4306.jpgIMG_4307.jpgIMG_4308.jpgIMG_4309.jpgIMG_4310.jpgIMG_4311.jpg
  15. Likes watchman, Vwdub2000, Lao liked this post
  16. #349
    Apr 2016
    Ipswich
    36 Post(s)
    Vehicle : Vectra C
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Year : 2003
    Mileage : 140000
    Got a link to those resistors mate?
  17. #350
    Regular Member ST200's Avatar
    Feb 2011
    Near Ikea M1 J26
    6 Post(s)
    Trim : VXR
    Engine : Z28NET
    If you can wait 5 weeks for delivery there's some on fleeBay here.
  1. Day with Dog_Book
    By strothow in forum Quick Photo Album
    Last Post: 18th October 2014, 00:57
  2. The Dog_Book
    By Dog_Book in forum Introduce yourself.
    Last Post: 15th October 2013, 23:16
https:www.vectra-c.comforumshowthread.php228315-Dog_Book-s-VXR-estate&goto=newpost
vauxhall 24435372
