Likes Likes:  3
Results 1 to 10 of 17
Thread: Help needed with electrics please
    Regular Member axelf's Avatar
    chester le street
    Default Help needed with electrics please
    Hi I have just bought a car from a well know guy on here @Slammedorion and it is perfect.. I am needing a little help to wire in the heated front seats and also the rear windows , I know the bulk of the work is done and i just need to fit the body loom.. I have all the wiring needed but electrics is something I don't understand haha , if any one could help I would be more than grateful.. Will to travel also PLEASE
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    @plasma maybe your man
    VIP-Member jaguser's Avatar
    Jul 2015
    Brockworth
    149 Post(s)
    Vehicle : insignia
    Trim : Sri
    Engine : 2.0cdti 160
    Year : 2010
    Mileage : It depend
    Happy to do it for u mate just need to figure out when i am closer up north.
    all the help you after can be found here
    Vectra SRi estate 165/230 CDTI 2006 XP
    Stret & Teapot tuned, fully blanked and deleted EGR, Precat & DPF deleted, FMIC, Silicone & alloy boost pipes, 4 bar TMAP Sebastian 56 small 7 blade turbo & 2.0 Injectors
  4. Likes Critch, axelf liked this post
  5. #4
    chester le street
    Quote Originally Posted by jaguser View Post
    That would be great thanks , I thought there might be a few more people up this way that is good with electrics but looks like that not the case
  6. #5
    Jul 2015
    Brockworth
    149 Post(s)
    Vehicle : insignia
    Trim : Sri
    Year : 2010
    Mileage : It depend
    i am actually not good with electric but it is basically lego. position - pin - in - click -next
  7. #6
    chester le street
    Well I can deffo say you will be better than me,,, all the work is done in the doors and switches for the heated seats , just got to fit the body looms, cut existing wires in the car and solder the ones from the looms plus fit the extra cables needed it's all here nod has all been activated too
  8. #7
    Jul 2015
    Brockworth
    149 Post(s)
    Vehicle : insignia
    Trim : Sri
    Year : 2010
    Mileage : It depend
    I can do it only if u have loom with pins mate.if there is cutting loom needed u cant solder it in the plugs. Not sure if i understand what u mean.the loom should have pins on wires.there shouldn't be any cutting involved in your car.if u dont have such a loom i suggest to contact @ppasma and buy from him ready tonfit loom.its not expensive
  9. #8
    chester le street
    Hi when SLAMMEDORION had the car he bought a donor car and removed all the bits that he needed... He removed the body looms from that car to, the wires that are not in my car are in these looms with the pins still intact to make the windows and seats work. But he cut the rest of the wires , these are the wires that is the same as in my car so these wires are the ones that require soldering... Hope this makes sense haha
  10. #9
    Jul 2015
    Brockworth
    149 Post(s)
    Vehicle : insignia
    Trim : Sri
    Year : 2010
    Mileage : It depend
    So if i understand front that removed loom theneeded wires can be separated and no need cutting or soldering as this should be very easy.
    On the other side u would need an expert in soldering to solder all the wires and hope for no cold joint.
    Can u post some pic of the removel loom?
  11. #10
    chester le street
    Yes that is correct the loom s I have have the correct plugs ant the wires that are needed still have the contacts on , so yes these wires can be removed and then added to the existing looms. But I do not know how to de pin them haha
  1. Electrics????
    By GRANTY in forum Electrical & ICE (including SatNav)
    Last Post: 10th March 2011, 02:45
  2. Electrics Help
    By gullarm76 in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2010, 20:09
  3. tow bar electrics
    By m8wos in forum Electrical & ICE (including SatNav)
    Last Post: 17th September 2010, 21:34
  4. 2.2 dti sri All electrics gone???
    By ShaneK in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2010, 14:34
  5. need some help with the electrics
    By paulzvectra in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2009, 18:12
