29th October 2016, 19:18
#1
Retro fitting bits and bobs questions....... HELP.
Evening all - I'll be getting a 2005 1.9 cdti elite model for breaking soon and was wondering if I can retro fit a load of the parts into my 2004 2.0dti energy model.
I want the leather seats.... Can I retrofit the heating switch etc.
Can I retro fit the stereo and Screen with the steering wheel which has the toggle wheel? (mine only has the 6 buttons)
Can I retrofit the rear electric windows?
Are the clocks, window switches etc all interchangeable?
Cheers all.
29th October 2016, 20:05
#2
You want to install full canbus stuff in a half canbus car.... use the search and look in the how 2 section.... it all can be done but the radio and screen will need rewiring and different connectors than the stuff needs to be activated.....with tech2 or vaux-com/op-com
The seats and the rear windows can be done easily but you will need to add the wire loom to the rear doors... the seats are just remove them fit them than install the fuses and the buttons.
