Results 1 to 2 of 2
Thread: engine oil
    Regular Member baz2003uk's Avatar
    Mar 2007
    swindon
    Default engine oil
    what oil would people use (will be doing a flush and replace at the weekend)
    im looking at using castol edge 0w 30 for my 1.9 cdti 2004
    Baz
    i'd just stick to VX's 5W30 longlife fully stynhetic as it's the only one endorsed to be used with that engine should it be fitted with a DPF..
    Oils have moved on so much, that you do really have to stick with the manufacturers choice or an EXACT specification match..
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. Yellow engine light staying on & engine getting hot.
    By Phil Campbell in forum Engine & Drivetrain
    Last Post: 20th March 2010, 08:56
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
