Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Clunking from suspension
    Regular Member Marky's Avatar
    Jun 2006
    North West
    Default Clunking from suspension
    Hi, my suspension on my '05 Vectra Estate has been making clunking noises for quite a while. But its intermittant. Its not always over bumps or going round corners. Sometimes it has happened whilst going in a flat, straight line.
    It sounded a bit like the suspension bush problem that other people have had.
    I have finally got aroung to getting it into the VX dealer. Now apart from them charging me £12 for a courtesy car (an Aguila!!!!!!!!). They will charge me £85+vat if they don't find a fault!!!!
    So I really want them to find the problem.
    People who have had the suspension bush issue can you remember a surefire way of replicating this clunking noise.
    So when I get a phone call asking me to demonstrate it I can.
    Cheers for the help.
    Regular Member Deadman's Avatar
    earth
    Are you sure you haven't snapped a spring? Sometimes you can lose a section from one and it'll sit in the bottom of the housing, the sharpened end (or break) can result in some strange noises.
    Have a good rummage around in the bottoms of the housings and see if you can fish any chunks of broken metal out if you haven't already.
    Jun 2006
    North West
    Broken springs . I hope not. Ive been transporting my 2 year old around for the pas 6 months with this noise going on.
    I haven't looked around at the suspension as I don't really know whats right and whats wrong.
    The noise does kinda sound like the spring is moving and slipping in and out of its cup.
    Hopefully, if it is a broken spring the VX should spot that pretty quick.
    Thanks for the suggestion.
    [Ex]Admin Duncan's Avatar
    http://forum.vectra-c.com/showthread.php?t=17564
    That may help - offers a couple of suggestions and mentions the spring seat mod in detail. Has yours had that done?
    earth
    Don't worry if it is, it's a very common but easily rectified problem.
    Good luck.
    Jun 2006
    North West
    Nope not had that mod done.
    VX might come up trumps and find the problem, but I'm not holding my breath.
    Think I might print these forums posts out and show them to VX.
    As usual the help on this forum is second to none.
    morton
    that does sound like the spring moving in its seat !? my hatch did it till i lowered it !
    Jun 2006
    North West
    Right then, think I'll focus on the spring in seat issue then.
    Re-reading some of the problems with the worn bushes it sounds like there will always be a noise when going over bumps.
    The spring in seat problem sounds as though its more intermittant
    Thanks.
    morton
    thats what i'd go for first ! its a cheap thing to try !!
    Jun 2006
    North West
    Thanks, but cost doesn't worry me.
    It should all be covered under warranty. Which is why I really want them to be able to replicate the issue. If they cannot, the VX garage will charge me a fault finding fee of £85+vat for 'wasted' time.
    Ridiculous really as I don't have the time or the inclination to book my car in for the day to sort an 'imaginary' problem. Ive got better things to do.
  1. Creaking/clunking from front suspension after bilstein & eibach upgrade
    By Telly Addict in forum Suspension, Wheels & Brakes
    Last Post: 25th August 2012, 14:53
  2. Replies: 11
    Last Post: 27th June 2012, 21:54
  3. Knocking/Clunking noise from front suspension
    By MrDerv in forum Suspension, Wheels & Brakes
    Last Post: 21st April 2012, 17:14
  4. clunking noise from front suspension
    By Billythebubble in forum Suspension, Wheels & Brakes
    Last Post: 16th December 2011, 23:21
  5. Clunking/Banging From Rear Suspension
    By kevin9885 in forum Suspension, Wheels & Brakes
    Last Post: 17th November 2009, 23:31
