Thread: Factory fit stereo to ordinary size stereo
    Regular Member videodoctor's Avatar
    Blackpool
    Default Factory fit stereo to ordinary size stereo
    Does anyone have any photos of a replacement car stereo being fiited using an adaptor kit from vauxhall?
    Ie Taking out the massive factory fit stereo and fitting a standard size stereo in its place?
    Regular Member Merick's Avatar
    Mar 2007
    Wigan & Preston
    I don't have any pics.. but i can tell you it's pretty easy. (Prices are approximations as i can't remember the exact prices)
    Buy the tool for removing the old stereo (Approx £4), it just slides out. Remove the old cage (the ISO connectors are clipped on to it, they'll need unclipping).
    Buy a facia from halfords for about £12 and fit the new cage for your new stereo, then the facia just pushes into the hole.
    That's pretty much all there is to it. Ignore the third ISO connector.. i think this is for the display, could be mistaken though. And you may need an aeiral adapter.. i can't remember if i had to buy one or not.
    Jan 2006
    Skynet HQ EMEC#5
    The facia kit I got was from Vauxhall, includes adapter harness, price was about £28
    Picture of my head unit here
    http://forum.vectra-c.com/showthread.php?t=18953
    Mar 2007
    Wigan & Preston
    Forgot to mention, you'll need an allen key to remove the little screws that block the holes..
    Here's a better write up..
    Take grub screws out of iso key holes, use iso keys to remove stereo.
    Undo 8mm or Torx20 bolt in the middle at the back of the cage.
    Use flat blade to release cage clips against front face of dash.
    Draw forward a little and get your hand or a flatblade into the hole, push the 3 plastic tags holding the iso block into the cage.
    Again use flatblade to pry aerial lead from 2 clips on cage
    use flatblade to push 3 clips holding aerial connector into the cage.
    remove cage.
    The wiring is very tight. Aerial lead may need an iso convertor/extender.
    Regular Member fellie's Avatar
    Lincoln
    will the vauxhall kit allow the steering wheel buttons to still work ?
    Jan 2006
    Skynet HQ EMEC#5
    No, depending on whether car is half or full canbus, you would need an adapter to plug into the radio loom. I fitted a Connects2 adapter to suit Sony headunit
    Mar 2007
    Wigan & Preston
    I took the display out and fitted a photo frame so i never bothered with the connects2 adapter.. can't get the sterring controls to work though.. stereo turns off when i connect it.. someone mentioned running a seperate power supply to it which i haven't tried yet.
    Lincoln
    probably looking at a better steering wheel anyways .. stereo buttons on wheel are no great loss... cruise.. now thats a different matter
    Mar 2007
    Wigan & Preston
    I used to have a touch screen stereo and found it pointless sorting out the steering controls when i could touch the screen.. would have kinda defeated the object.. however, now i've got a new stereo, i'm still teaching my brain where the buttons are so i don't have to look.
  1. Calling ICE/stereo experts.. Dvd/stereo, will this fit in my Pre-face Vec C Gsi?
    By TAB in forum Electrical & ICE (including SatNav)
    Last Post: 27th February 2013, 13:20
  2. Factory Fit Stereo specs?
    By keith1983 in forum Electrical & ICE (including SatNav)
    Last Post: 20th November 2012, 22:04
  3. Vauxhall Stereo size question
    Last Post: 12th November 2007, 22:54
  4. iPod & factory fit stereo?
    By Adam in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2007, 17:04
  5. Can't remove my factory stereo, help.
    By muffking in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2006, 01:07
