Results 1 to 10 of 15
Thread: Bluetooth
    Regular Member sgmiller's Avatar
    East Calder, nr Edinburgh
    Default Bluetooth
    Hi,
    Is there a definitive answer regarding the best bluetooth kit to fit to the vectra.
    I would love one that used the screen in my car. I have seen a few references to the Parrot kit as well as the Vauxhall kit but unsure which one to go for. Any pics available if it fitted?
    I have the CD70 SatNav if that matters.
    Regular Member ukanalyst's Avatar
    Jul 2006
    Cheshire
    I personally can't recommend the Parrot 3200LS Colour enough ... superb bit of kit. You may wish to double check your handset will be compatible first though @ http://www.parrot.biz
    HTH
    Dave
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    I installed the Parrot 3200 & apart from having a faulty head unit on the 1st one I have no complaints - easy to fit & works well even with a Nokia N73
    Regular Member G.O'Rilla's Avatar
    Jul 2006
    On the road
    I got the parrot 3100 (I didn't think the extra money for the screen on the 3200 was worth it) and it is just superb.
    Works with both Qtek 9100 PDA and Nokia 6230i
    Feb 2007
    Kent
    Happy Parrot 3200LS owner here too. I bought the just launched Autoleads SOT-109 lead and literally had the kit fully fitted and working in under 30 minutes. The SOT-109 is only suitable if you have the prewired phone VDA loom behind the glovebox. Takes the power and links to the headunit from here without need to remove h/u or cut any wires. It cuts sound source and displays MESSAGE on display during call.
    Quote Originally Posted by G.O'Rilla View Post
    Swindon
    I have the Parrot 3200 kit installed as well. There are a few different options on where to fit the unit, some use the air vent, others on the dash, i chose just to the right of the stereo, as everyone says, easy to use, works through the stereo speakers and come's up as external on the stereo when in use with the CD70.
    Voice activation and if you have photos stored on your phone for people the photo will appear on the parrot screen as well as the phone.
    Jul 2006
    On the road
    Quote Originally Posted by tonyt View Post
    Mine (3100) is above the right air vent.
    Photos of callers?? Now I know why I didn't get the 3200........ most of my contacts in photos look as though they should be holding up a little board with numbers on it
    Regular Member Paddy2bsure's Avatar
    Hertfordshire
    I have done several Parrot CK3100 installs now, and it really is a fantastic bit of kit. On the newer facelifted Vectra's (as well as the current Astra's) you need a SOT122 adapter lead AND an ignition-controlled live feed - the cigarette lighter on a Vectra is the best source of this (note: on an Astra this source is constant live - DOH - as I discovered on Saturday evening).
    Also, make sure the "mute" lead from the Parrot unit is connected to the appropriate pin on your head unit (via the SOT122 lead) then your head unit says "Extern In" when you're on a call - otherwise it won't show anything out of the ordinary. There's a little diagram on the top of your head unit (once you remove it) showing you what connectors are what on the back of the head unit.
    Lastly, on CanBus Vectra's (rotary controls on the steering wheel, NOT buttons) you don't need a radio code when removing the radio - it's mated to the ECU on the car.
    Jul 2006
    On the road
    The more I use it the more impressed I am with it. The Engineer who installed it (correctly) also said it was the best bit of kit he had seen - in fact went by his recommendation as he has done several installs for me
    Regular Member Coastie's Avatar
    Feb 2007
    Suffolk
    A couple of my mates fit car kits for a living in the Norfolk Suffolk area and cant speak highly enough about the parrot kits, getting one myself soon as the Nokia pile of ****e car kit (CK20w) keeps freezing the head unit (CD70), and its becoming troublesome !!!
    Go for the 3200 all +'s that ive heard ! and im gonna have one 2
  1. bluetooth
    By R2XPT in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2011, 22:29
  2. bluetooth car kit
    By walker in forum Electrical & ICE (including SatNav)
    Last Post: 19th April 2008, 16:16
  3. bluetooth 2
    By Graeme in forum Vectra C / Signum Car Chat
    Last Post: 23rd April 2007, 14:34
  4. cd 70 bluetooth
    By m1w in forum Electrical & ICE (including SatNav)
    Last Post: 12th April 2007, 23:09
  5. bluetooth
    By Eddie Dee in forum Electrical & ICE (including SatNav)
    Last Post: 21st March 2007, 08:50
