Results 1 to 10 of 16
Thread: can anyone help? car pulls to the left
    Regular Member kev bux's Avatar
    Jan 2006
    BOROUGHPETER
    confused can anyone help? car pulls to the left
    hi,
    took my car in a few weeks ago cos it was pulling to the left,had wheel allignment checked and was ok.i have recently had new suspension fitted(koni's)and had the camber set and fitted new drop links as i was getting some knocking which is now cured. tyre pressures are ok too but still pulls to left. any ideas out there.
    thanks
    morton
    bottom arm perhaps? i had to fit a new one of these then had to get it tracked up again !!
    Jan 2006
    BOROUGHPETER
    hi veccy22
    did yours pull to the left then?and are the bottom arms something that are known to wear?.
    if so what would i be looking at price wise.i've got first m.o.t coming up end of may and i would like to get this sorted before then.
    cheers.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    now i know this sounds saft but have you checked the tyre presh ?
    sorry didnt read it lol.................check for play in the track control arms
    morton
    all i know is that when the new one was fitted ! the tracking was miles out ! which was wierd as the steering was fine ! the bottom ball joint was shot and it was scrubbing the tyre ! is was about £50 i rekon !
    Regular Member Oscar Ding Ding's Avatar
    Mar 2007
    Oldham
    Are all your tyres the same age, the reason I ask is mine also pulled to the left had it back to Vauxhall three times, checked the alignment,tracking etc. Turned out that one of my tyres was newer than the rest and had more tread. I swapped the front wheels from left to right and the pull to the left dissappeared. Hope this helps
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Quote Originally Posted by Oscar Ding Ding View Post
    If your tyres have a directional tread you shouldn't swap them from side to side!!
    Some cars just have a tendency to pull to the kerb, following the camber of the road. Try driving down the middle of the road (straddling the white)line to see if it still pulls left, preferably when there are no cars coming the other way!!
    Mar 2007
    Oldham
    The tyres aren't directional, as you suggested I tried driving on the opposite side of the road to see if the car followed the camber of the road (pulled to the right this time) it didn't it still pulled to the left. I took it to an independent garage to have the aligment and tracking checked, (I wasn't conviced Vauxhall were checking it properly), turns out there was nothing wrong Vauxhall were right. It was one of the Vauxhall mechanics that suggested swapping the wheels.
    Jan 2006
    BOROUGHPETER
    ok lads, thanks for that.ive got khumo 712's on the front and khumo 711's on the back.gotta change the back tyres now cos i whacked a kerb in mcdonalds car park the other night and took a chunk out the side wall so now ive ordered the same tyres as the front,a pair. was not happy.
    not really done too much damage to the wheel thank f***.
    cheers.
    Full Member
    Luton
    Default Wheel alignment
    I had quite a bit of grief with my Omega, and the Signum has not been fantastic either re alignment. In a nutshell, I now use a tyre place which has a Hunter DSP400 full geometry rig. Costs about £25 for inspection and then £12.50 per adjustment. And a guy who knows what he is doing....
    Even when `properly' aligned, both the Omega and the Signum will pull slighly to the left in the UK, and slightly to the right in France. ie they follow the camber.
    Check the tyres have the `bias' set symetrically - this is the coloured band which is painted around the circumference on a new tyre. In other words the colours bands should be set as mirror images on each side of the car.
    The other thing which also has quite an effect is the camber angle of the front wheels - even 1 degree difference can be felt. In fact you can adjust the car for UK roads by playing with the front camber. (no good when you go to France though !) The only problem is the Vectra C and Signum are not that adjustable, apart from the play in the bolt holes ...
  1. pulls like a train above 2000rpm but??
    By Gerdo3 in forum Engine & Drivetrain
    Last Post: 8th July 2012, 20:56
  2. V6 CDTi pulls like a rubberband
    By Hummelshøj in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2011, 22:18
  3. Car pulls to the left
    By ScottR in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 10:15
  4. 1.9 cdti pulls right on acceleration. normal?
    By MCD in forum Engine & Drivetrain
    Last Post: 1st March 2009, 19:28
  5. Car pulls to left...never guess what dealer said!!
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2008, 11:59
