Thread: Help!!
    Regular Member Marty J CDTI's Avatar
    Feb 2006
    Yeovil
    confused Help!!
    Just been out an spent the evening sprucing up the motor, however went to try and get in it, and the Bl***y keys won't work tryed my battery in the wifes an that didn't work still, however I managed to get in by manually opening the doors (after setting the alarms off!!) and start the engine with both keys and now they're fine both open and close the doors etc!! Why has this happened an will I need to get the keys Tech 2'd so the car recognises them?
    Jul 2006
    If they both open and close the doors now, why would you want to fix them?
    Feb 2006
    Yeovil
    Because I don't want them to stop working again out of the blue! I know it sounds strange but when your stood looking like a plank trying to get into your own car while the alarm is going off, it tends to ask the question is this going to happen again!
    VOTING UKIP IN AVELEY
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    not to sure what would of caused that....but as paul they arnt broke now so need to fix them
    Feb 2006
    Yeovil
    Ok well if it happens again I shall give post the "I told you so "" haha.
    Admin plasma's Avatar
    On the Forum
    291 Post(s)
    Engine : 150
    Mileage : 74000
    Has happened to me once before, the car loses track of the key for some reason, (i've heard if the button has been pushed too many times outside the range of the car then the key throws a wobbly), once inserted into the ignition it resynchs itself says hello to each other and then decides it will start working... dunno why the 2nd key didnt work though?
    Feb 2006
    Yeovil
    Perhaps it was because I swapped her battery with mine to check it wasn't just the battery. Dunno, fingers crossed it will all be ok now.
    Thanks for the help.
