Thread: Apparently.......
    Regular Member david.aka.judas's Avatar
    Suffolk
    Default Apparently.......
    the EGR valve can fail.....thats unusual.......
    another item replaced.........
    Regular Member Kcs's Avatar
    Feb 2007
    Tamworth
    Yep they can get all glupped up ! you can clean them out though, but you will need a new gasket, i'm not sure were it is on the Vecy ? my last oil burner, being of the TDCi type was at the front left, only had to drop a pipe and undo a few bolts ! How much did they sting you for the valve ?
    Suffolk
    good old network q m8 - only had the car 5months and so far its had 3 goes at the wheels to balance, rear spring mod, ecu update, rear water leak, rear demister, front hub, overfilled oil.
    did sum1 say extended warranty........?
    Suffolk
    on a run today and guess what....the light back on even after the egr replacement......
    I can offically say that my car is s hi t........
    Feb 2006
    Dorset
    bet mines worse ........
    Administrator plasma's Avatar
    On the Forum
    410 Post(s)
    Engine : 150
    Mileage : 74000
    least yours runs
    Regular Member willc01's Avatar
    UK Motorway Network + some smaller roads
    Quote Originally Posted by DennisTheMenace View Post
    no, bet mines worse than yours, vx have still to get to the EGR, they've done the injectors nw on the fuel rail. Seems to be try one bit at a time and hope it works and if it doesn't change something else and it doesn't run. Not bad for 1 year old
  1. I'm a racist....apparently
    By the_wave_rider in forum General Chat
    Last Post: 30th January 2013, 16:20
  2. My 120 1.9 is apparently a bit smoky
    By firebeast in forum Vectra C / Signum Troubleshooting
    Last Post: 30th September 2012, 20:08
  3. apparently i have had a claim
    By neverlandandy in forum Insurance Chat
    Last Post: 13th August 2009, 00:04
  4. Apparently it's Panacotta...
    By Penfold101 in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2009, 19:13
  5. It's Ready ....apparently...
    By DennisTheMenace in forum Vectra C / Signum Car Chat
    Last Post: 29th October 2006, 13:11
