Results 1 to 10 of 21
Thread: Clunk when pushing the rear wheel
    Hampshire
    Default Clunk when pushing the rear wheel
    Hi all,
    had a search to see if I can find anyone else suffering from the same issue but no luck...
    I have a clunk when going over bumps, I have already replaced the shocks as they where well and truly dead, however the clunk is still there
    If I push and pull the wheel from the top it make a clunk when pushing but not when pulling, and it only does this on the top of the wheel and not the sides.
    had the wheel off and can not see anything obvious.
    any ideas?
    cheers
    RichPu
    Administrator plasma's Avatar
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    Mr Gsi will know this one, think hes at work, so will see this when he trawls through all the new posts.
    Mileage : 000
    It might be one of the bushes on the suspention,they have a tendancy to wear out from time to time. more so if you pull a trailer or caravan.
    Regular Member grumpano's Avatar
    North West
    It was the same with mine mate...Bushes sorted it..
    Hampshire
    Hi grumpano,
    which bushes was it, as I had a look today and there seems to be plenty to choose from
    RichPu
    North West
    Anti roll bar bushes mate.Seems like a common fault.
    Hampshire
    Thanks,
    Will have a look this week to get them done
    RichPu
    North West
    Ok mate no problem.The bushes cost about £10..
    Regular Member benny's Avatar
    Feb 2006
    dudley
    ive had this on myn and i changed the shocks and the top arms to fix myn jack the back up and check for free play in the top arms and for leaks around the shocks
    top arm bushes..but they only come with the arm attached.. easy to change as well, so DIY....
  1. Servo pushing oil through turbo
    By Cheech in forum Engine & Drivetrain
    Last Post: 15th December 2012, 17:45
  2. changing discs and pads, pushing pistons back.....
    By taffy bhoy in forum Suspension, Wheels & Brakes
    Last Post: 9th October 2012, 22:33
  3. Clicking sound when pushing on clutch
    By TonyTangles in forum Vectra C / Signum Troubleshooting
    Last Post: 12th April 2011, 22:25
  4. Clunk from driver side front wheel?
    By rosssri in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2011, 07:37
  5. i have a clunk
    By solorider in forum Vectra C / Signum Car Chat
    Last Post: 1st March 2009, 22:03
