Results 1 to 10 of 22
Thread: leak no leak
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : Insignia
    Trim : SE
    Engine : 2.0
    Year : 2011
    Default leak no leak
    since i got my MOT problems sorted out at the dealers i mentioned that i was using a lot of coolant (every 6 or 7 weeks id top it up by half a pint) they checked for an leaks but could not find any, so they steam cleaned the engine then covered it in talc then was sent on my way told to return last friday.
    took it back last friday and still could not find any leaks was then sent away and told to come back on wed, just looked under the bonnet to see if i could see any leaks and there is no sign of a leak BUT my coolant has droped by nearly half a centimeter.
    does this mean the leak is internal and if anything is wrong wot is it.
    any ideas and solutions much needed for when i return to dealers on wed.
    Administrator plasma's Avatar
    On the Forum
    410 Post(s)
    Engine : 150
    Mileage : 74000
    check your oil level see if its risen. All check to see if its gone funny, maybe water leaking via the head gasket into the oil,
    Apr 2006
    Vehicle : Insignia
    Trim : SE
    Engine : 2.0
    Year : 2011
    oil is fine first thing dealer checked
    On the Forum
    410 Post(s)
    Engine : 150
    Mileage : 74000
    maybe leaking into the exhaust manifold or engine and being burnt off? I had to refill my coolant from bottom of the tank twice during the course of me owning my car.. Had it pressure checked and they cant find a problem.. covered 50k now
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Talc is only any good if you check just after a run while the engine is still going. Once you stop, the leak will also stop and the coolant will evaporate and may leave no trace. Oil will not evaporate so it stays but coolant is water in the main and will not hang around long.
    Regular Member stickshift's Avatar
    North London
    Quote Originally Posted by nutron View Post
    I thought modern coolants were designed to get into every nook & cranny of the system to dissipate the heat and as a side effect show where a leak was with either blue or pink staining (depending on colour) when it dries out.
    Apr 2006
    Vehicle : Insignia
    Trim : SE
    Engine : 2.0
    Year : 2011
    im pretty sure its internal but finding it well thats the hard part my network q warrenty has run out but they have agreed to finding and fixing the leak.but i dont know who long they will do it for if dealer cant find the leak.
    it does sound like its internal. Keep pushing them. If they have agreed then keep on them till they find it
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    True, if there were a large leak it might stain the talc but the talc will get grimmy very quick and make it difficult to spot.
    We use it on gas turbine engines to find leaks but we run it then check straight away.
    Just ask the garage to do a coolant pressure test.. that'll tell you if there's any leaks anywhere in the system.. but V6's do have a nasty habit of leaking water from the water pump and from the oil/water cooler matrix..
  1. Oil leak 150 cdti oil leak help
    By sr_fly in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2011, 20:46
  2. Oil Leak
    By Tam80 in forum Engine & Drivetrain
    Last Post: 17th January 2011, 13:41
  3. Oil leak
    By Rich2.2 in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2010, 20:31
  4. Leak, front end creak, refurb, bent locking wheel key and another leak =(
    By nick-v2.2 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th February 2010, 19:58
  5. 3.2 oil leak from?
    By megaderek in forum Engine & Drivetrain
    Last Post: 29th September 2009, 22:45
