Thread: squeeky front seat
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    Default squeeky front seat
    has any-one else got this problem or is it just me but the drivers seat is starting to propper do my head in with its squeeking, first of all it was only when the seat was adjusted but now its like it all the time, sounds like a dodgy old mattress and getting worse, and before any smart @rse says its to do with my weight it makes the noise when my son is sat in it and he weighs 6.5 stone wet through.... the dealers originaly said they cant find a fault so im stuck with it
    Midlands Mod Shop - NFFC.
    Regular Member Beavis's Avatar
    Blackburn Lancashire
    if in warranty get it back to them,I have no noises from mine (well some!!)
    SOMERSET
    That's funny because this happened to me about six month's ago and YES it drove me nuts
    From memory i think i lowered the seat and totally moved it in all postions then put it back to how i wanted it and the noise stopped. Forgot until this post that i had this problem
    Regular Member ukanalyst's Avatar
    Jul 2006
    Cheshire
    Yep I have this problem from time to time with mine and had it in my last Vec ... the squeek drives you crazy on long drives!
    Regular Member rosssri's Avatar
    S.Lanarkshire
    Is there anyway you could get into it with wd40? Try pumping & tilting seat right up and try and get into it that way from underneath
    chester
    Ditto - have had a squeaky driver's seat since car new 9 months ago. Brought car in for it's first service and they quizzed me to figure out where the noise is coming from, upshot is they have ordered a new seat base. Heard also the lumbar support setting can causes squeaks!
    Also my boot trim was split the part that covers the boot lock. they changed that there and then.
    Trim : Get a
    Quote Originally Posted by PIMM View Post
    glad that worked for you m8 but mine is not stopping in any / all positions
    looks like a call to the dealers is needed
    Trim : Get a
    Quote Originally Posted by rosssri View Post
    i will try this if the dealers have no idea and try to blag it..
    Regular Member jontymo's Avatar
    Feb 2007
    Huddersfield
    Mines the same!!!!
    jontymo
    Regular Member Kcs's Avatar
    Feb 2007
    Tamworth
    Mine doesn't squeak, it kind of makes a dull knock when i set off, i think its one of the pivit points under the seat !
  1. squeeky drivers seat
    By marc vectra sri in forum Bodywork & Interior
    Last Post: 19th July 2011, 21:42
  2. Front seat
    By bigmac in forum Bodywork & Interior
    Last Post: 26th June 2009, 19:29
  3. Front End Sounds Like Squeeky Old Bed
    By ukmayhem in forum Suspension, Wheels & Brakes
    Last Post: 14th June 2009, 15:12
  4. squeeky drivers seat
    By graememk in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2008, 23:04
