Results 1 to 3 of 3
Thread: Squeaking noise from back left of car?
    Regular Member RSV_Ecosse's Avatar
    Falkirk, Scotland
    Default Squeaking noise from back left of car?
    At first I thought this was the parcel shelf ( my auld Calibra's parcel shelf used to make a similar noise ), but after refitting it, the squeaking noise is still there, randomly.
    It doesnt do it all the time, just every so often. This might sound strange, but it sounds like a "metallic squeaking" if that makes any sense?.
    As I said, just does it randomly, sometimes when going over speed bumps, sometimes not. Sometimes when turning left around corners, sometimes not.
    It's driving me up the wall!!!.
    I dunno if its a suspension related squeak or suchlike, anyone else had this?.
    SOMERSET
    Go to the back of your car and put one hand on top of the boot and the other has if you were going to open the tail gate and move it up and down and see if there is any play or slight movement in the tailgate. If thats the problem then just take of the plastic cover near the spare wheel off and very slightly lower the boot locking mechanism/ catch.
    Regular Member j13hdb's Avatar
    Nottingham
    On a Signum there are 2 black rubber covered bolts that screw in and out and if you have any play as above you can also try turning the bolts a little bit at a time and this will stop the boot moving as well-pressume the same in a Vec?
  1. Squeaking/odd noise
    By DaKemps in forum Suspension, Wheels & Brakes
    Last Post: 19th June 2012, 23:01
  2. Squeaking noise
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2012, 11:04
  3. squeaking noise when cold
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 29th November 2011, 15:47
  4. squeaking noise
    By deepak in forum Vectra C / Signum Car Chat
    Last Post: 16th August 2011, 17:20
  5. Another Squeaking Noise
    By Damian in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2007, 07:54
