Results 1 to 10 of 18
Thread: Lambda Sensor???
    Regular Member LAV6Y's Avatar
    Oct 2006
    Lisburn, NI
    Talking Lambda Sensor???
    Can anyone tell me what the LAMBDA SENSOR is and what it does???
    Cheers dudes!!!
    if measures the emissions of the car and provides info for the cars ECU to alter the fuel /air mixture
    Oct 2006
    Lisburn, NI
    thanks for the info mate.
    PS: How did i know it would be you that would be first to reply!!!
    That seems to be a common trait through-out all threads... You are certainly on the ball.
    ... we try our best
    Mileage : 000
    Beat me to it again "eh" Mark.
    Oct 2006
    Lisburn, NI
    He always does!!! Has he got a computer stapled to his head or what???
    [Ex]Admin Duncan's Avatar
    Further to what Mark said, they're also referred to as Oxygen sensors as they measure the amount of Oxygen in the exhaust gases thereby working out the AFR. (air to fuel ratio)
    Oct 2006
    Lisburn, NI
    Has it a parameter setting then?? If it does what happens if these parameters aren't met?
    then the emissions light comes on , on the dashboard..as the ECU can't alter the fuelling to correct values..
  1. where to buy Lambda Sensor
    By signum04 in forum Electrical & ICE (including SatNav)
    Last Post: 4th May 2012, 08:56
  2. Lambda sensor
    By danno91 in forum Vectra C / Signum Troubleshooting
    Last Post: 26th August 2011, 16:06
  3. Lambda sensor
    By dan1983 in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2010, 13:08
  4. lambda sensor
    By deg in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2009, 18:35
  5. Lambda sensor - Z32SE - where is bank 1, sensor 1?
    By Kev_A in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2008, 14:46
