Results 1 to 10 of 13
Thread: Steering rack help needed
    Mar 2007
    dublin
    Default Steering rack help needed
    Hi all
    Just got a vectra and today while parking the fluid leaked out.
    It had a new rack fitted 18000 miles ago, any ideas what could be wrong
    could be seals, pipes, or the like.. it needs a proper look at, if you think you may not be able then get it into a garage ASAP..
    where does the fluid seem to leak from under the car?
    Regular Member steve.o's Avatar
    Jun 2006
    walking in memphis
    Are you sure it was brake fluid and not condensation from the aircon?If it was water,and you have had your air con on that is not a problem as all cars fitted with air con do this.
    Mileage : 000
    Has the power steering fluid leval gone down......... bit of a pig to check for though. that would eliminate the "water" on the ground...as to steering fluid.
    PS hows thing Steve.
    Mar 2007
    dublin
    just had a look seems to have dumped all fluid as the power steering is non existant looks like maybe a pipe came off the resovoir, how do i get at that?
    right, if it's condense, it'll be water,..if it's PAS then it'll be a deep red colour.. what is the fluid?..
    Take the bumper skin off the front of the car
    the pump and res is under the drivers headlight.. and the best way to access it is to remove the bumper, there is a HOW2 in the section on how to do it
    Mar 2007
    dublin
    its deffo oil but not red in colour, smells like hydraulic oil
    is it yellowish?...if it was PAS it's be a bit red..
  1. Steering Rack!!
    By kevinmc in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2012, 23:02
  2. HELP - New Steering Rack needed for the Vec-B.
    By Vaux-Man-G in forum The 'Off Topic' room
    Last Post: 30th June 2011, 16:00
  3. which steering rack?
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2011, 22:09
  4. Steering Rack?!
    By Alank in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2011, 12:17
  5. steering rack
    By pjabrid in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2010, 22:47
