Results 1 to 2 of 2
Thread: Disconnecting Battery
    Regular Member Neil's Avatar
    Feb 2007
    The pool
    Default Disconnecting Battery
    Hi Guys
    Are there any known problems in relation to disconnecting the battery for 1/2 hour or so?
    I have just installed a K&N filter and it has been said that the ECU needs to reset and so by disconnecting the battery this will happen
    i have a facelift 2.2 Direct SRi if that makes a difference!!
    Can anyone tell me if the disconnection is required - it must be said that the filter has been in a week now and it hasn't made a blind bit of difference to the performance - Have I just wasted £45?
    [Ex]Admin Duncan's Avatar
    There shouldn't be any issue with disconnecting the battery - other than you'll need to reenter the radio code and reset your auto windows.
    As for whether the reset is required due to fitting the K&N, I have my doubts. It's supposedly so that the ECU then 'learns' from a 'reboot' how the engine behaves with the filter in. I can't see why it wouldn't 'learn' from just being fitted.
    At the end of the day, the resetting will have caused no issue. As for whether the K&N is worth it on that engine, there are guys who have fitted one who I'm sure will be along to give their thoughts.
  1. When disconnecting the car battery.......
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2009, 17:27
  2. For those disconnecting battery with ESP!!!
    By rushy in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2007, 22:07
  3. Disconnecting the battery
    By badge25 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd June 2007, 12:40
  4. Disconnecting battery...
    By danBoy in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2007, 23:06
  5. disconnecting the battery!
    By carl bear in forum Electrical & ICE (including SatNav)
    Last Post: 26th March 2006, 22:17
