Results 1 to 10 of 11
Thread: SRi Springs
    Jul 2006
    Default SRi Springs
    Removed today from my 1.9CDTi Estate - can someone tell me if the rear ones will fit non-estate models?
    Will lower approx 20mm from standard.
    16,500 miles old (if it makes any difference).
    £30, delivery to be discussed - they're flippin' heavy!
    Jul 2006
    morton
    estate and signum models are different mate !
    Jul 2006
    I wasn't sure, only because the Eibach springs only have 1 option for rear axle weight, so that's obviously not an issue, but wasn't sure if the actual shape & size would fit other models.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    I thought sigi's were built on estate floor pans, so the same underneath?
    Jun 2006
    Wigan
    Default springs
    I'll have em mate if they'll fit vectra LS dampers on a hatch back? will u be at PVS?
    Regular Member wardy's Avatar
    Chichester
    estate & signums are the same platform, which is longer than the hatch/ sloon. Not sure if the springs would be different estate to hatch though. I would have thought that they may be different facelift to pre-facelift though as VXL made much fuss about the improved suspension.
    morton
    my 'c' came with eibachs fitted already ! trouble is they were for estate/signum models ! which meant it sat up at the back as the rears are load barers !
    Jun 2006
    Wigan
    Sorry mate can't have those springs, spoke to local Vaux dealer, they said facelift springs won't fit prefacelift model and hatchback springs for rear are different to estates. I'll have to keep looking. Cheers mate.
    Feb 2007
    work
    andy - if you need some i have the complete suspension from a 2004 cdti hatchback PRE facelift, 2004 reg.. pm me if interested dude
  1. replacing standard springs with Sri springs
    By mon in forum Handling & Braking
    Last Post: 31st December 2012, 22:03
  2. springs? coilovers? shocks/springs?
    By Dan. in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2011, 19:01
  3. Replies: 5
    Last Post: 21st July 2010, 16:14
  4. vxr springs
    By supersione in forum Handling & Braking
    Last Post: 18th July 2010, 16:21
  5. 2.0T SRI Springs
    By Baz07 in forum Parts for sale
    Last Post: 9th July 2008, 13:28
