Thread: P0130 code
    Apr 2013
    Torbay
    Vehicle : Vectra c
    Trim : Shine
    Engine : 1.8
    Year : 03
    Default P0130 code
    Need help with my 1.8 petrol vec c
    Just a quick overview: when I start the car the revs are high about 2000rpm then after a minute it seems to lower back down but continues t idle really rough. I did a obdII test and got code p0130 lean condition. I thought it was the O2 sensor so I changed it, then checked for a vacuum leak but couldn't find any (but to be fair I don't really know what am looking at) anyway the long term fuel trim is at +12% and the short term fuel trim is at +11%. Any ideas would great.
    Regional Organiser - South something area HarrysDad's Avatar
    Jul 2014
    Camberley, Surrey
    95 Post(s)
    Vehicle : Insignia A FL
    Trim : Elite Nav S/S
    Engine : A20NHT
    Mileage : 79774
    Which Lambda sensor did you change? P0130 is usually bank 1 sensor 1 which is the sensor in/nearest the manifold.
    Check HERE for upcoming meets/events
    Apr 2013
    Torbay
    Vehicle : Vectra c
    Trim : Shine
    Engine : 1.8
    Year : 03
    I changed the one attached to the manifold just before the cat.
    Regular Member petrol_head16v's Avatar
    Jul 2015
    Bedfordshire
    Vehicle : Vectra-c estate
    Trim : SRI CDTI150 SAT-NAV XP2
    Engine : 1.9
    Mileage : To much
    Check the cat isn't blocked or twisted look thru the top lamda hole and up from the botton
    Aug 2014
    Netherlands
    Vehicle : Corsa C
    Trim : Elegance
    Engine : Z14XE
    Year : 2002
    7 kg/h air mass is a bit to the low end. Would expect more like 8-9-10 kg/h and you're problem is gone. Try new genuine or siemens air mass meter.
  1. fault code help code p1565
    By Hodgy in forum Engine & Drivetrain
    Last Post: 3rd January 2021, 15:11
  2. P0130 sensor location
    By zzr600 in forum Engine & Drivetrain
    Last Post: 27th August 2014, 21:56
  3. Error code reading and code readers
    By Ben50n in forum Engine & Drivetrain
    Last Post: 27th August 2012, 16:43
  4. Car Pass - Result! Key Code & Radio Code
    By mxt in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 13:01
  5. EML - Vec B 2.2 Sri 150 - P0134, P0130
    Last Post: 20th September 2010, 10:51
vectra p0130
