Results 1 to 10 of 15
Thread: Can you turn off the traction control
    Regular Member lee_eardley's Avatar
    Back to waddington,Lincoln)
    Default Can you turn off the traction control
    Is it possible to turn of the traction control on the veccy C 1.9 cdti elite.
    there is not a switch as standard...
    Is it possible to get one wired in?
    Jul 2006
    Mexico
    You can get the switch itself at the dealer m8, but as far as I know, might or might not work. In my case didn´t, but there are some lucky members that got TC by just adding the switch. It´s no expensive to try. Good Luck!
    Look behind the blanking cover first of all. If there is a blue plug then you've got a chance - no blue plug means no chance. Then get yourself a TC switch (part number in the part numbers section) and give it a try. Even with the blue plug being present it's 50/50 whether it will actually turn off the TC. There's no pattern of model, engine or year as two people with the 'same' car have ended up with one working and the other not.
    Southampton
    Local VX dealer managed to permanently disable mine without asking then refused to admit it had TC when I complained... I sure your nearest dealer could mess yours up to :-)
    Regular Member Merick's Avatar
    Mar 2007
    Wigan & Preston
    Could you not just remove the fuse or is the fuse needed for other things?
    On certain engines, 2.0T for example, pulling the fuse will kill the engine, or won't let you start it even if you pull it with the engine off.
    Mar 2007
    Wigan & Preston
    I won't be trying that one then!! I don't have the blue plug for TC in mine... i guess i'm stuck with it on! lol
    i have got the blue connector, so i am gonna try and get a switch to turn it on and off.
    What advantages is there to having it turned off??
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    plenty of burning rubber i guess.....if thats what you want lol
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : Insignia
    Trim : SE
    Engine : 2.0
    Year : 2011
    Quote Originally Posted by lee_eardley View Post
    no advantage just lots of smoke and a bigger tyre bill
  1. traction control
    By vectraross in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2012, 17:51
  2. how do i turn my traction control off?
    By yatesy in forum Suspension, Wheels & Brakes
    Last Post: 1st January 2011, 18:28
  3. Traction Control
    By Tam80 in forum Bodywork & Interior
    Last Post: 19th September 2010, 10:10
  4. can u turn off traction control?
    By 8786melle in forum Diesel Engine related
    Last Post: 5th May 2009, 13:57
  5. traction control
    By happypostie in forum Electrical & ICE (including SatNav)
    Last Post: 15th February 2009, 12:50
vectra c tc off
vectra c traction control turn off
traction control on vectra tdi turn off
