Results 1 to 10 of 28
Thread: squeaking noise!!! aaaaaarrrgghhhhhh!
    Regular Member tallica371's Avatar
    Mar 2007
    North London,middlesex
    Unhappy squeaking noise!!! aaaaaarrrgghhhhhh!
    Hi all!!
    I was was wondering if anyone out there can help.
    i drive a veccy sri on a 03 plate.
    When driving for about 10-15 minutes i can here a poxy squeaking noise coming from my passenger side wheels from 30mph onwards! i think its the front one.
    i only noticed this recently as ive been driving with the windows fully open due to the warm weather.
    The noise STOPS as soon as i touch the brakes. Also ive noticed the noise also stops when turning right?? My pads look fine but the discs are a bit worn.
    ive tried brake cleaner & even abit of wd40 in certain areas but to no avail.
    any ideas???
    tallica371
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    have u checked for stones/debri around the disc etc?
    Mar 2007
    Yes. ive had the front wheel off twice now & gave everywhere a good clean. the dam noise is doing my head in!
    Full Member Big Sig's Avatar
    Its probably the pads not clearing the disk. Maybe they need removing and that anti-squeek pad replaced - A sticky pad that holds the pads to the caliper/piston so they return slightly and clear the disk.
    the caliper could be stickin on the sliders too.
    Mar 2007
    The car is going into PNG next week for an M.O.T so i will tell them the problem whilst its there. Only problem is that if they (or whoever gets the job!) cant hear the noise i'm going to get stung for £75 per hour labour which they charge,look like a plum & still have the squeaking noise for my troubles.
    manchester
    hi,
    it could be your hub and wheel bearing I had a similar problem have them checked
    Mar 2007
    Cheers. will do. will let everyone know what vauxhalls say & how much it cost IF they can find the problem. Just gutted that i could of used that money for a new irmscher grille!!
    Regular Member Stevie-B's Avatar
    Mar 2007
    NI
    I have the same problem as well. Was told the pads were too tight!!!!! and needed to be copper greased......
    Mar 2007
    Did copper grease solve the problem?
  1. Squeaking/odd noise
    By DaKemps in forum Suspension, Wheels & Brakes
    Last Post: 19th June 2012, 23:01
  2. Squeaking noise
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2012, 11:04
  3. squeaking noise
    By deepak in forum Vectra C / Signum Car Chat
    Last Post: 16th August 2011, 17:20
  4. squeaking noise on start up?
    By darlodouth76 in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2010, 19:29
  5. Another Squeaking Noise
    By Damian in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2007, 07:54
