Thread: Drivetrain Question.
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    Default Drivetrain Question.
    whats does the circled part insert into?
    are there any bearing/seals that could wear used on the end?
    any help would be great.
    Carl
    Regular Member simac's Avatar
    Wirral
    Looks like the drive shaft to me which goes into the transmission/diff
    Mileage : 000
    It is the inboard constant velocity joint, it goes into the gearbox, there is another one on the other side and two outer CV joints that go into the wheelhub, they sort of articulate so the wheels can rotate and turn at the same time and "bend" when the car goes over a bump in the road.... A real feat of engineering really, not many people know what they do or look like,but just take them for granted, people talk about will the gearbox take the increase in touque when they fit a tuning box, but do not think about the CV joint, A lot of clever designe and engineering and manurfacture goes into this part that works silently and un noticed............. As to bearing and seals wearing out, it is not un common for them to "break" but quite rare, they are very sturdy and well made...
    anyone know a rough price for replacing a cv joint on the vec (1.8ls 2003)?
    its the gearbox end on the passenger side.
    i noticed the other day that the cv boot was not secured on the driveshaft end.
    why do you need to replace the joint, is it worn out??.. if it's just a loose boot then why not just re grease the joint and re secure it with a new band clamp ( not a cable tie)..
    Jul 2006
    Mexico
    As far as I know CV joint get damaged if the plastic boot around breaks, dust, water, etc. comes in and ruin them.....so is very wise to check the plastic boot every now an then.
    the cars goin in the garage on monday to see if thay can find the grinding/scratching im gettin when brakin, and ill get them to check the joint, regrease and seal it all back while its there, i was just thinkin that the grindin may be somethin to do with that. and was just wondering a rough guide price to replacin it, if it needs replacin.
    Mileage : 000
    It might sound daft, but could the caliper be catching on your new wheels, as when a CV joint "goes" it normally make a sort of clonking noise especially when on full lock, they dont normally make a grating sound, why do you think it is that particular CV joint??
  1. Drivetrain Noise - The Dreaded DMF!!
    By andyburt in forum Engine & Drivetrain
    Last Post: 28th June 2011, 20:11
  2. Vaux-Com / Op-Com question - Screen change question
    Last Post: 16th May 2010, 23:54
  3. Vectra Sri 3.0 CDTI drivetrain shunting issues
    By MadFrank in forum Engine & Drivetrain
    Last Post: 14th December 2009, 20:10
  4. new tonight drivetrain query ?
    By danoel in forum Engine & Drivetrain
    Last Post: 11th February 2008, 14:00
  5. Drivetrain wobble at certain speeds - causes?
    By APJ in forum Engine & Drivetrain
    Last Post: 2nd November 2007, 13:46
