Thread: Fog Light
    Regular Member Merick's Avatar
    Mar 2007
    Wigan & Preston
    Default Fog Light
    i'm getting a warning to tell me one of my bulbs have gone.. the only one i can find is a fog light on the rear passengers side. The bulb is ok though as i swapped them around and i got the same result. Left knackered, right working.
    The left one seems to have a wire missing though.. a black/blue one but it's not in the loom anywhere... it should connect to the pin that goes to the fog light, the only reason i know it's black/blue is because theres one on the right side..... is this normal?
    Mileage : 000
    There is only one fog light that works on the rear of the Vectra.......... The one on the right, yes there is a bulb on the left but no wire to it though.
    Mar 2007
    Wigan & Preston
    Ahh, i see, so theres something somewhere else it's complaining about then.
    Cheers Ed.
    Work your way logically through the lighting circuits
    Switch the lamps to sidelights
    Check the front, then the numberplates lights
    Switch the lamps to dipped, full beam, front and rear foglights, indicators (hazard)
    The remaining lights should now all be on
    Finally, to check the rear lights either get someone to stand at the rear and press the brake pedal (making sure all the high level brake light bulbs come on) and reverse
    If you can't get someone to check for you, find a retail park and park with the rear of the car facing the shop window
    If all of these are OK, then have you changed any bulbs recently?
    Feb 2007
    North west
    can be as simple as a build up of dirt or carbon on a bulb contact, clean up the terminals if in doubt.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
