Results 1 to 10 of 28
Thread: Wheels appear off balance?
    Regular Member pauls898's Avatar
    Malvern
    Default Wheels appear off balance?
    Car was going fine, until I had to replace my front tyres as the were worn
    Had two brand new Goodyear NSTC5 tyres fitted exact same type size and make as original ones fitted, drove off, got wheel vibration at 65 - 80 MPH
    Took it back, got another man at tyre depot to check balancing, found the one to be 15 grams out and the other 20 gram out , re-balanced
    Same result, wheel vibration at 70, worse
    Took to different tyre depot and they found one was still 15 grams out other 10 grams out re-balanced.
    Now ever worse vibration, this is getting silly I thought, so I have now swapped the front and back tyres around, slightly better, but still not happy ?
    Is there any way, that with them jacking the car up at one corner at a time on a trolley jack that they could have damaged the anti roll bushes or dislodge the suspension causing this vibration, wheel bearings seem ok as I have pulled and pushed on them and there’s no play?
    Its really starting to annoy me now, as the car used to drive so smoothly, now it shakes my wrists to bits
    Anyone else had this problem after replacing their tyres, or is all these tyre depots got doggy balancing machines???
    Regular Member david.aka.judas's Avatar
    Suffolk
    it took vx 3 goes to fix it on mine, apparently, its a common problem and they had to balance them using a fine setting.
    no problems now, thank god.
    the best bet is to take it to vx - coz most tyre dealers aren't the smoothest, especially when theres a problem.
    yep, it's HIGHLY unlikey to be any form of other damage..
    Vectra's and Signums are VERY sensitive to their balancing and if you go to any old tyre fitters they will just throw on the lead and leave you to it..
    you need to find a quality fitters...mine now know only to balance it on 'fine' and to do 2 more runs after they've added the weights.
    Suffolk
    yes....I'm got an approval....come on....lol
    hey, if you're right, you're right....
    Check where the valve and weights are fitted
    I had to have them refit a new tyre when I pointed out the valve and weights weren't in the right place
    The tyre should have a red dot and this is the weak point of the tyre, and should be as near to the valve as possible
    Suffolk
    didnt know that one, thats worth remembering next time vx do my tyres and the steering wheel shakes out of my hands...........****** vectra...........why do we bother?
    Malvern
    I asked the fitter man that, but these new tyres don't seem to have that Red dot anymore, he told me they stopped putting them on the new tyres?
    Chester
    Quote Originally Posted by pauls898 View Post
    This will tell you why the Vec. (amongst others) is so sensitive. You need static and dynamic balancing done on fine settings as above.
    The Vec. is the first motor I've ever had which my local fitter could not balance. The place that did it correctly used a balancer_like_this_one.
    In the absence of any suggestions of places local to you they have a search facility which will locate the nearest one.
    Just a suggestion
    SOMERSET
    I have had a wobble ever since i put on 18's and know 19's and 3 years on it still wobbles ??? I ignore it
  1. Wii Fit and Balance Board
    By andy13 in forum General items for sale
    Last Post: 16th April 2009, 17:33
  2. Rear Wheel Balance
    By bgm46 in forum Suspension, Wheels & Brakes
    Last Post: 4th January 2009, 22:53
  3. Tyres Wont balance
    By korlinski in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2008, 16:00
