Thanks Thanks:  2
Likes Likes:  1
Results 1 to 9 of 9
Thread: Swirl flap blanks, what dimensions to make them?
    Dec 2014
    Hants
    Vehicle : 1.9 CDTi Signum
    Trim : Elegance
    Engine : Z19DTH
    Default Swirl flap blanks, what dimensions to make them?
    Any one know what the dimensions are for the swirl flap blanking plugs? ive just bought a manifold and want to clean it out and blank it all off. Would be nice if I could make the blanks up so they are ready for when the manifold gets here.
    Graham
    Oct 2013
    Derby
    340 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Just get it welded up, its easier to weld without the blanks in place
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
    Dec 2014
    Hants
    Trim : Elegance
    Engine : Z19DTH
    I was planning on plugging then welding in the plugs.
    South Central England
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Engine : Z19DTH
    Year : Nosey
    I made up plugs and had them welded in, less chance of distortion then but I can't give you dimensions unfortunately. If you make them about 20mm, you should be able to take up any gap or quickly reduce down an aluminium plug from there.
    Feb 2019
    Estonia
    Vehicle : Vec C sw
    Trim : xx
    Engine : Z19DTH
    Year : 2008
    What material is the inlet manifold made of?
    Can you just weld it with a regular MIG welder?
    Regular Member Hoody86's Avatar
    Jan 2019
    Fife
    Trim : Exclusive
    Engine : 1.9 cdti Z19DTH
    Mileage : 127K
    For the cost of the material just buy them from flebay lol they ain't expensive
    Jan 2019
    Fife
    Trim : Exclusive
    Mileage : 127K
    Also no you cannot mig a cast part will need to be tig
  8. Thanks blackrusty thanked for this post
  9. #8
    Oct 2013
    Derby
    340 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Quote Originally Posted by blackrusty View Post
    It’s an aluminium alloy, tig then and don’t bother with blanks just weld up its easier for the welder that way
  10. Thanks blackrusty thanked for this post
  11. #9
    Feb 2019
    Estonia
    Vehicle : Vec C sw
    Trim : xx
    Engine : Z19DTH
    Year : 2008
    This is how I finally decided to solve this. Bought a 3/4 UNC thread tap. Threaded the manifold. Threaded a piece of steel which I then used to thread a 20mm diameter plastic rod.
    Screwed the plug in with a pipe wrench and then cut off the excess. Repeat. Looks rough, but that's good enough for me.
    Overall cost 10€ for the tap.
    Also unplugged the EGR and everything works fine.
    Hardest part for me was unscrewing the oil separator nuts/bolts.
    57026374_1167817920064623_590792877781549056_n.jpg56899675_687453661669562_195447009405042688_n.jpg
    This is what the manifold looked like before cleaning.
    340 000 km on the clock
    52332967_2114794761947300_727936075510579200_n.jpg52688621_1919293614866811_6974502941348593664_n.jpg52601916_628098380964630_4355213313362100224_n.jpg52601860_236255583993322_7805402190536769536_n.jpg
  12. Likes Dog_Book liked this post
  1. swirl flap bar
    By dhorsfall2000 in forum Engine & Drivetrain
    Last Post: 13th November 2015, 10:53
  2. swirl flap bar mod
    By mikeyp40 in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2014, 17:17
  3. Swirl Flap Kit
    By andsaw in forum Diesel Engine related
    Last Post: 21st August 2013, 23:47
  4. swirl flap
    By elite lee in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2012, 21:49
  5. Swirl flap actuator
    By jofenan in forum Engine & Drivetrain
    Last Post: 12th October 2011, 21:01
https:www.vectra-c.comforumshowthread.php224483-Swirl-flap-blanks-what-dimensions-to-make-them
z19dth swirl flap plug size
