Thread: cars goin to the garage monday.
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    Default cars goin to the garage monday.
    Im gettin a metal on metal grinding/scratching when brakin medium to hard from the fornt passenger corner.
    ive had a look at the obivious and its had new discs and pads recently, that never helped.
    ive looked at the backing plate, calipers, caliper bracket, wheel. ive looked for lodged stones etc.
    im hopin they will find the problem as its been goin on for a couple of months now and its doin my head in.
    im thinkin it cud be bearings, but it only happens under braking (thought it might be because of the extre force applied when braking).
    Nicking Ya Dinner.
    Might just have the answer, check the engine shield, last mech that serviced mine managed to break it in half, granted I started the split rummaging around on my back last time I did it, but he finished it off for me, tucked it back up and said nowt, out of interest I reported it to hear the bull they'd come out with, and sure enough, wait for it....the mechanic seems to think you've hit something, and for good measure he also ripped a 5 inch section off of it to make it look authentic, we can put another one on for you sir it's only £200 fitted, no thanks says I, but it now falls down every now and again, and makes just the sound you describe as it drags the floor.
    ill have a look, i did hit something in the road a while back actually.
    thanks for that mate.
    Regular Member Harry's Avatar
    Uxbridge, London
    ask spoons what happens when the lower engine shield comes loose at 130mph!
    had a look last nite, all is fine with the engine shield part.
    Regular Member 111's Avatar
    Stockton-on-Tees
    This happened to me, It turned out to be the pads even though there was 3/4s left on them. They looked as if the wear pad had cracked. I changed them and all is fine. There was no signs of over heating or anything been trapped.
    might fit a new set of pads this weekend, see if that helps, if not, ill be leavin it for the garage to find. hopefully they will.
    cheers
  1. Is it ok to contact a cars previous owner if bought from a garage?
    By TimTay in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2011, 21:22
  2. Two guys wandering around a garage full of old cars
    By VXR_DV in forum The 'Off Topic' room
    Last Post: 2nd July 2010, 15:24
  3. Cars back from garage again
    By Graeme in forum Vectra C / Signum Car Chat
    Last Post: 17th August 2005, 20:49
