Thread: C Vxr/opc
    ohrid
    Default C Vxr/opc
    Wasnt it 255 BHP?
    Why I am seeing 280 BHP version?
    History anyone, was the 280 BHP introduced recently, and were the performances improved?
    In late 2006 the performance was raised to 280ps from 255ps matey.
    ohrid
    Thanks.
    Max speed still 161 mph?
    Acceleration still the same?
    deffo more traction problems that's for sure.
    ohrid
    You know I discovered that if you let go of the gas pedal in the corners, it has no understeer whatsoever ;-)
    I really like the OPC, if I had to buy a sports car it would be the OPC.
    Regular Member In a states's Avatar
    Dec 2005
    In an estate car
    0-62 for the hatch is down to 6.1secs, estate 6.3.
    Same torque and the suspension has been tweaked for the better.
    Regular Member VXR_DV's Avatar
    South Coast
    The main difference with the engine is that it does pull a bit harder above 4500rpms due to better breathing and a slightly different map.
    And on reasonably warm tarmac, with the standard Conti's, even with a bit of throttle, there is lots of grip
    dv.
