Likes Likes:  6
Results 1 to 10 of 11
Thread: Aux-In switch for CDC40
    Full Member Robsey's Avatar
    North East Cheshire
    24 Post(s)
    Trim : Energy
    Mileage : 131,000
    Default Aux-In switch for CDC40
    I have thrown this thread together, to show the simple wiring changes required to allow Aux-In to be used with a CDC40 set-up.
    The main proviso is that a DAB box must also be fitted in your car.
    There are other threads on here, but they tend to get a bit cluttered after a while with discussions and questions.
    So to that end, I do not claim intellectual property on the following information - Although I did produce the wiring diagrams and pin-out to hopefully clarify most queries.
    So - here goes.
    Wiring in an Aux-In socket to a CDC40 with DAB module.
    The DAB Connector.
    This is the standard 18 pin DAB Quadlock connector.
    We are only interested in 4 wires from this plug.
    Pins 1 and 10 are for left audio.
    Pins 2 and 11 are for right audio.
    See the pin-out here.
    Now then to fit Aux-In, we have two choices.
    Either a switch to allow us to listen to either DAB or your auxiliary device.
    Or
    Cut the four audio wires from the DAB connector, and wire these directly to a 1/8” (3.2mm) jack socket or jack plug. In this configuration you will not be able to listen to the DAB. Only the auxiliary device.
    It is my assumption that you would prefer to have the choice, and therefore we would need to fit a 3-pole double throw switch.
    If you have the correct switch, it will have 9 pins on it.
    Often termed as being “on-off-on latching”
    Here is how to wire your switch.
    The switch has three rows of pins.
    The first row is from the DAB box.
    The second row (identified as the common row) will go to the CDC40 head-unit.
    The third row will be wired up to you auxiliary socket or plug.
    As a further quirk, you could use a four pole double throw switch, whereby you could use the fourth set of contacts to illuminate an LED when the switch is set to DAB or Aux-in.
    Or a different coloured led for each function.
    That is up to you really.
    Strangely the 4 pole switches seem to be easier to get hold of from places like Maplins etc. RS and farnell online also do a wide range of switches
    Although there are loads of 3 pole switches available on ebay and other similar auction sites.
    There is only one further step, and that is for those who also wish to add a DAB module.
    The wiring details are on the pin out.
    but remember - If you are not using Tech 2...(In otherwords using OpCom / Vauxcom).
    retro adding a DAB module will entail divorcing your current CDC40 and display - fit the DAB box, and then marry it all up together again.
    Tech 2 is different as the infotainment modules are installed indevidually - not simultaneously.
    Good luck.
    One final pointer - The aux-in audio will only work as long as the DAB box is getting a suitably strong signal reception.
    If the signal strength drops, the DAB module mutes the audio.
    regardless of whether you are switched to DAB or Aux-In.
  2. Likes Woody, GSiFan, Dog_Book liked this post
  3. #2
    North East Cheshire
    24 Post(s)
    Trim : Energy
    Mileage : 131,000
    Further Info - Possible extra wires.
    For people upgrading from CD30 to a full system CDC40, GID and DAB box, you may need to add further wires between your head-unit and display.
    There are the serial Data wires.
    Blue on CDC40 pin 33 to GID pin 8,
    Yellow on CDC40 pin 39 to GID pin 9 and
    Brown on CDC40 pin 12 to GID pin 24.
    These wires are not said to be required on BID or CID.
    Then there are the obvious Mid Speed CAN wires from -
    DAB box pin 3 to Display pin 17 (green)
    DAB box pin 12 to Display pin 18 (white).
    DAB power and ground wires can be spliced into the same wires as the head-unit, as they both use Fuse Fi1.
    Regarding the DAB connector - check behind the glovebox for an 18 pin quadlock.
    Vauxhall can be very hit and miss, but some vehicles have the connector in place - others do not.
  4. Likes Woody liked this post
  5. #3
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    189 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    @Admin .. This is a fantastic and well documented mod, immediately worthy of being placed in the "How2" section IMO
    Woody's Vx Ice Addons UK/Eire Distributor of the Comfort Unit and Video Accessories from www.PepaS.cz Designed to enhance your Headunit & Display these add in Additional Data and Reversing Camera & Media. NOW INCLUDES FULL Vxr/OPC NEEDLE SWEEP & LIGHTS Also CD70 Aux In & 3 Line Display Updates.
  6. #4
    Regular Member RBH's Avatar
    Jan 2008
    Central Scotland
    108 Post(s)
    Vehicle : Insignia VX Line
    Trim : SRI
    Engine : 2.0 CDTI
    Mileage : 46k
    Brilliant thread
  7. #5
    North East Cheshire
    24 Post(s)
    Trim : Energy
    Mileage : 131,000
    I have to point out that this is my interpretation of the various threads.
    I have merely condensed and clarified the information already provided.
    I personally have not yet fitted DAB to my Cavalier, as popular thought was that I should retain my CD70.
    So it would be good if one or two members could confirm that I have got it correct before we even consider How 2 status.
    I have the whole kit except the aux-in switch, should I ever change my mind.
    Hmm - a free-standing project for the summer maybe.
  8. Likes Woody, RBH liked this post
  9. #6
    Regular Member dougie89's Avatar
    Dec 2011
    Dalton-in-Furness (NW)
    62 Post(s)
    Vehicle : 6
    Trim : Sport
    Engine : MZR-CD 2.2
    Mileage : 77k
    Definitely worth sticking
  10. #7
    Timisoara, Romania
    Trim : Estate
    Engine : Z19DT
    Mileage : 210.000
    I tried retrofitting the DAB (I already had Opera in place and working but no DAB so far) but it is not working for me. As there are no digital broadcast radios in Romania, I have just cut the 4 audio wires (2 audio signal + 2 audio ground) from DAB and used the wires from the Head Unit plug to connect to the aux-in plug. But the DAB unit is switched to "mute" and can't undo this no matter what I tried: switching on/of the Head Unit, switching Opera to "mute" several times, restarting the car so the DAB gets a shock...none of these is working for me, but apparently worked for other guys here in Romania...
    Does anybody know any way to prevent the DAB from switching to "mute" the audio outputs?
  11. #8
    North East Cheshire
    24 Post(s)
    Trim : Energy
    Mileage : 131,000
    Sorry - it is all done automatically by the dab unit / cdc40.
    If a sufficient dab signal is found, audio is enabled.
    If there is insufficient dab signal, then audio is muted.
  12. #9
    Full Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    I also live in Romania, so no DAB signal, but the Aux-in mod works as "advertised" here. I think Alin's problem is a wiring problem.
  13. #10
    Mar 2017
    Milton Keynes
    Vehicle : vauxhall
    Trim : vectra c
    Engine : 1.9 cdti
    hello guy's!! i have a short question,i was make aux in with dab but i can use it just in uk.why,wich is the secret?
  1. CDC40 Opera Aux in / DAB Switch
    By russy47 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd March 2018, 12:47
  2. For Sale: drivers door switch with rear windows switch
    By rozzer2006 in forum Parts for sale
    Last Post: 24th December 2013, 10:11
  3. Changing Facelift Passengers Door Switch to Preface Switch
    By THEHITMAN in forum Vectra C / Signum Car Chat
    Last Post: 22nd December 2013, 00:32
  4. For Sale: Blue led converted headlight switch with rear fog switch only
    By RBH in forum Parts for sale
    Last Post: 2nd October 2013, 13:39
  5. CDC40 to CDC40 MP3 upgrade.... any advice?
    By eamond in forum Electrical & ICE (including SatNav)
    Last Post: 15th September 2012, 08:02
cdc40 aux pins
