Thread: Eibach springs on standard shocks...
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    Default Eibach springs on standard shocks...
    Will it be alright to still use my standard shocks when I buy an Eibach spring kit??
    Probably not.... the active uses the 'LS' suspension, so lowering it -30mm may lead to the shocks bottoming out...it's far safer to use them with the SRI style shocks as they are already -15mm, so are much less prone to bottoming out.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Also, the std absorbers will have to work harder than they were designed for and will therefore wear out quicker. Work harder as the energy to absorb will be the same but over a shorter moving distance = more work.
    Take Marks advice and get either SRi shocks or uprated shocks to match the springs.
    Feb 2007
    work
    i have sri shocks and springs 4 sale.......
    Jun 2006
    Lake District
    Vehicle : Vauxhall Insignia
    Engine : CDTi 160
    Mileage : 53.000
    Quote Originally Posted by danBoy View Post
    Wassup Dan, you dont trust me?
    The reason i said they are OK to use with standard shocks is that from what you read about them on various forums and on the specs on different websites, many many people use specifically Eibachs with std shocks...just aslonmg as they shocks are in good condition.
    Leicester
    Eibach springs are designed to work with standard or uprated dampers.
    In the Vectra C's case, the Eibachs are designed around the standard damper setting, so you will be fine. SRi dampers or other uprated dampers will just make the set up even better.
    Your looking at 25-30mm drop on non SRi suspension, or 10-15mm on SRi/GSi suspension, just ensure you buy the set with the correct axle weight.
    Regular Member kev666's Avatar
    Mar 2007
    North West
    Well I have got the lowered springs on my signum with standard shocks, and boy has it dropped from the Elite high setup. The only thing that I have noticed is that if i go over a speed hump to quick they WILL bottom out.
    As far as I am concerned (just my opinion) it all depends on what you want from the drop. For me it is just cosmetic. If you want to throw your car round the twisties then go for a shock/spring setup. If you just want to lower your car for the look then use the standard shocks. If the shocks go over time so what, buy some more. You would have bought some anyway if you were going down the shock/spring setup.
    Its your call but why throw away the shocks when there is nothing wrong with them???? use them till they are dead and then change them
    Kev
    As has been proven time and time again by folks on here like Spikey.. if you use standard shocks they WILL bottom out as the damped stroke is shortened by the amount you will lower the car by, when you fit the lowered springs..
    Shorter shocks have different valving to cope with the shorter travel they have..
    FACT.. not all vectra shocks are the same...
    I stand by my recommendation above.. if you have SRi suspension then fine, use the -30 eibachs...but if you have standard suspension you may well suffer jolts as the shocks bottom..
  1. Eibach springs & Bilstein shocks
    By george1987 in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2010, 20:02
  2. Lowering Springs on Standard Shocks
    By bizerk in forum Suspension, Wheels & Brakes
    Last Post: 14th March 2009, 01:51
  3. will springs fit with standard shocks
    By mat osborn in forum Suspension, Wheels & Brakes
    Last Post: 12th July 2008, 21:12
