Likes Likes:  4
Results 1 to 10 of 19
Thread: cdti 150 dump valve
    Regular Member davieboy1976's Avatar
    hamilton scotland
    Default cdti 150 dump valve
    Looking for any info here, I'm pondering with the idea of fitting a dump valve on my sri cdti 150, don't know much about these but looking for something a bit different for my car, would this help with the lag you sometimes get and does anyone know how these sound on a diesel.
    The car has a de-catted straight through exhaust fitted with a pipercross air filter and a blanked off egr valve, also has a tuning box fitted, cheers.
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    133 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    Quote Originally Posted by davieboy1976 View Post
    It ill make your car sound like a chavmobile, and will not reduce lag at all. It may even reduce performance.
    Would be better to solve the problem that is causing the lag, and get a decent remap at the same time. You can have bags of torque from 1500rpm when these engines are correctly tuned.
    hamilton scotland
    What's the difference between a map and a tuning box, I paid £300 for mine a few years ago.
    Regular Member fatfred's Avatar
    Dec 2013
    Bristol
    Engine : 1.9 CDTI 120 8V
    Mileage : 87K
    Tuning box = cheat
    Teapot map = How Vauxhall should have done it
    Shimples!
  5. Likes HarrysDad liked this post
  6. #5
    hamilton scotland
    Quote Originally Posted by fatfred View Post
    Tuning box = cheat
    Shimples!
    What sort of gains are to be had then if I ditch the box and go for a map, also what are the rough costs, cheers
  7. #6
    Dec 2013
    Bristol
    Mileage : 87K
    Cost wise I'll let Paul answer. It may be that you'd be better going for a remote remap or posting in the regional area.
    Gain wise what do you want?
    My 120 was putting out 120 (funny that) now it's closer to 160 BUT it is so much smoother that I can drive it on the mway in 6th which I couldn't do before below 85 mph ( private road obviously). I asked to have my torque limited due to the box but it is much more than it was (approx 10% over the max rated for box).
    Basically a PROPER remap will give you a car you will enjoy!
  8. #7
    Regular Member jayday's Avatar
    Aug 2014
    Wakefield /Selby
    12 Post(s)
    Trim : Sri 150 cdti
    Engine : 1.9
    Get Paul to remap it for you!! Mines mapped and is a lot better to drive than on a tuning box
  9. #8
    hamilton scotland
    Bhp and torque increase!
  10. #9
    Aug 2014
    Wakefield /Selby
    12 Post(s)
    Trim : Sri 150 cdti
    Engine : 1.9
    Yep, and all smoothly delivered with no issues
  11. #10
    South Central England
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I know many don't like dump valves and are very aggressive in their rejection but I see no way it should reduce performance and it could indeed reduce lag but only if set up correctly. Whether you are actually talking about lag or something else is a different question.
  1. dump valve on a vectra cdti 150
    By webtrawler in forum Diesel Engine related
    Last Post: 23rd June 2011, 11:34
  2. 1.9 Cdti Dump Valve
    By Kev_G in forum Engine & Drivetrain
    Last Post: 6th April 2011, 16:25
  3. Blow off/Dump Valve 1.9 CDTi
    By SamT in forum Diesel Engine related
    Last Post: 11th November 2010, 17:26
  4. Free dump valve on 3.0 CDTI ??
    By Vectra_Power in forum Diesel Engine related
    Last Post: 17th September 2009, 00:49
how to fit dump valve to vectra c 1.9cdti www.vectra-c.com
