Thread: TC Switch
    Regular Member dan1983's Avatar
    North London
    Default TC Switch
    Hi where can i get a tc switch from. And also what are the other connectors behind the blanks for. I have four, red, blue, green and white.
    thanks.
    Mileage : 000
    You will be able to get the switch from a VX dealer. I am not sure of the part number, but it may or may not work on your car, it is very much the luck of the draw i,m afraid. The switch costs about a tenner incl vat. the other connectors I presume you mean for the reversing sensors, sports switch. alarm.. if the switch,s do not work they still look nice and replace the blankng plug with something better to look at.
    No doubt some one will pop a long with all the relivent part number,s and prices, so you will see how much it will cost to do a bit of a mod.
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    Quote Originally Posted by dan1983 View Post
    thanks.
    TC switch plugs into the BLUE connector immediately under the blank under the 'Alarm' button. Got one myself recently from a VX dealer cost £11.64 inc. VAT and the part number is 13138265, and its called a TC or ESP switch.
    I have an 04 Edition 100 like you, and it worked straight off on mine.
    When you press the switch and the engine is running it switches TC from on to off or vice versa. For safety reasons TC cannot be disabled over about 37mph. TC is disabled if the TC symbol remains illuminated under the dials after pressing the switch (unless you're doing over about 37mph when it is re-enabled for safety reasons). If you press the switch after you turn the ignition on, and immediately before you start the engine, it will be disabled when you start the engine.
    HTH
    John
    Regular Member Neil's Avatar
    Feb 2007
    The pool
    the top 2 are for left and right heated front seats.......
    Though about replacing them for a microsecond when I found out how much the switches were - especially when they won't work as I don't have heated seats!!!!
  1. Small 12v Auto circuit for on/off switch for PDC switch
    By markm in forum Electrical & ICE (including SatNav)
    Last Post: 8th October 2012, 23:00
  2. Clutch Switch & Brake Switch
    By spennny in forum Electrical & ICE (including SatNav)
    Last Post: 29th June 2011, 12:01
  3. headlight switch window switch in blue
    By delboy2028 in forum Parts for sale
    Last Post: 26th May 2010, 08:56
  4. t/c switch help
    By kitchcav in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2007, 18:02
