Thread: Would safeguard stop vectra c Sri from starting?
    Regular Member trebor1411's Avatar
    Jul 2012
    co.durham
    Vehicle : vectra c 1.9cdti sri 150
    Default Would safeguard stop vectra c Sri from starting?
    Can anyone please help?
    I recently fitted a new starter motor on my vectra c Sri 1.9cdti. Since connecting the battery my car won't start and I've got 'safeguard on the dash readout. I've sat in the car while it's locked and the alarm does go off so it can't be the ultrasonics. Anyone got any ideas? Better still anyone got a tech 2 lives near county Durham? Cheers folks.
    Regular Member dougie89's Avatar
    Dec 2011
    Dalton-in-Furness (NW)
    67 Post(s)
    Vehicle : 6
    Trim : Sport
    Engine : MZR-CD 2.2
    Mileage : 77k
    Did you connect the starter properly? Have you checked your fuses
    Jul 2012
    co.durham
    Yes mate, starter was fitted correctly, but also in addition I forgot to mention that the boot won't open either
    Regular Member fatfred's Avatar
    Dec 2013
    Bristol
    15 Post(s)
    Vehicle : Insignia
    Engine : 1.6D
    Year : 2018
    Mileage : 1 hundred
    Did you disconnect the battery when you fitted the starter? It does sound like a fuse has blown or an earth problem.
    Try posting a help request in your region and get the diagnostics done. I'm sure someone will help.
    Jul 2012
    co.durham
    Checked connections for rear heated window as the heated windscreen don't work either. So it's a combination of the boot won't open, heated rear windscreen and turn signal lamp for left rear indicator. Any suggestions, getting desperate.. Cheers folks.
    Regular Member Da n's Avatar
    Jun 2013
    manchester
    16 Post(s)
    Vehicle : vauxhall signum
    Trim : elite
    Engine : z32se
    You could loop the safe guard wires together to get rid of the message and try it
    Sep 2011
    newcastle
    estate or hatch ?
  1. Can't stop water pump leak vectra c 1.9cdti
    By 02carlton in forum Diesel Engine related
    Last Post: 4th November 2015, 14:33
  2. Starting to like my vectra now !!!
    By renton608 in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2011, 01:07
vectra c safeguard wont start
