Thread: third gear vibration
    Regular Member kojak01's Avatar
    Feb 2007
    edinburgh
    confused third gear vibration
    hey folks.i have a 04 plate 1.9 cdti sri vec c with a rather anoying third gear gear vibration. when slowing down in third gear if i let my foot off the accelerator there is an all mighty vibration through the gear stick. not felt in any other gear. its in with vx at minute to have this fixed but they are telling me that they are waiting on new gear selection cables and an engine mount. bit of a stab in the dark me thinks. has anyone come across this before on their travells?? if so what sorted it?? ohh by the way its a 6 speed manual box as if you hadnt guessed!
    cheers
    kojak
    Regular Member Kcs's Avatar
    Feb 2007
    Tamworth
    It could be internal, ie: worn selector ! mate had his done last year.
    The cables and rear engine mount are totally feasable as the cause of it, not a fob off in my opinion..
    Feb 2006
    Guttedsville
    When you say vibration, do you mean it's actually visibly moving, or you can feel it?
    If it's what you can feel and it's only gently vibrating, then I think you'll find all of them do it, certainly any manual 'boxed car I've driven anyway.
    If it's a harsh vibration, then I reckon they're on the right road.
    Regular Member silvermachine's Avatar
    Riding a wave of Torque!
    Was this ever cured, cos mine does the same thing.
    Feb 2007
    edinburgh
    Thumbs up third gear vibration
    hi. yes the fault was eventually sorted by another vx dealer. turns out as suggested that the third gear synchro was worn causing the gear to vibrate when slowing down(or coasting down). as the car was stil under warranty managed to get a replacement box out of the. bonus. alo had the flywheel replaced due to a knock on taking up drive and had them replace clutch at same time. driving as it should now. appolligies for never posting the outcome before!!
    cheers
    kojak
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2016, 16:15
  2. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  3. Vibration from the gear leaver/wire
    By maerfr in forum Vectra C / Signum Car Chat
    Last Post: 12th December 2011, 00:18
  4. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  5. 5th gear vibration
    By Paulmac07 in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2006, 00:49
