Thread: Check Strap
    Regular Member Neil's Avatar
    Feb 2007
    The pool
    Default Check Strap
    Can anyone tell me if the check strap (bar of metal that stops the door flying away in the wind) is covered by warranty?
    My car is only just over a year old the strap ain't 'alf making a racket!!
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    I would think so, Volvo used to cover them when I worked for them a few years ago.
    HTH
    Nicking Ya Dinner.
    One of my rears does that, sounds like a 20 yr old door that never made it to the oiling party in time.
    Regular Member dezzie's Avatar
    May 2006
    blackpool
    Smear the metal part in vaseline, trust me! we use it on the metal parts on our upvc windows at work when they start going stiff, 100 times better than wd40 that only last about a week
    Jun 2006
    Lake District
    Vehicle : Vauxhall Insignia
    Engine : CDTi 160
    Mileage : 53.000
    Is it the actual strap, or the bolt that holds it to the body?
    These bolts seem to come loose quite regularly, and when they do, it makes the clonk sound.
    Full Member Big Sig's Avatar
    Quote Originally Posted by dezzie View Post
    WD40 isn't an oil thats why. It will actually remove oil. A drop of 3in1 or engine oil will do the job.
    Feb 2007
    The pool
    The only thing that I have is spray grease and it hasn't made a blind bit of difference!!
    Suppose will have to contact main stealers in the moring and get it sorted - It drives me mad
    Regular Member kicker's Avatar
    Oct 2007
    West Midlands
    confused
    I've been asked to check my fathers vectra as it clonks twice when closing/opening. he kept it greased since it starting knocking just once, but did'nt work. is the bolt visible or is it a interior panel off job??
    cheers
    Regular Member simac's Avatar
    Wirral
    Quote Originally Posted by BigP View Post
    HTH
    Yep, been there with an 850. The welds in the A piller used to break so the bracket would make that horrible clonk !
    My Vectra doors it too on the drivers door occasionally, using spray grease helped mine a little but it's still there.
    Regular Member wardy's Avatar
    Chichester
    It IS covered for sure. I had both fronts done on mine at the 2year service FOC under the warranty.
    I messed about with grease etc, but waste of time (noise always came back). If it's under warranty get them changed.
  1. Check Strap Clicking/Knocking Door noise
    By msqualo in forum Bodywork & Interior
    Last Post: 1st June 2012, 13:02
  2. Check strap
    By a6lns in forum Bodywork & Interior
    Last Post: 21st August 2011, 14:23
  3. drivers door check strap busted
    By valvelift in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2011, 12:12
  4. Door Check Strap!
    By @ndy-e in forum Bodywork & Interior
    Last Post: 5th October 2009, 15:01
  5. Check strap fitting
    By wazza007 in forum Bodywork & Interior
    Last Post: 11th August 2008, 12:31
