Thread: air box mod
    Regular Member dan1983's Avatar
    North London
    Default air box mod
    hi how do i do the air box mod on a 2.0t?
    thanks
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    there should be a how2 somewhere.....all you have to do is take off the cover to the airbox.the screws will loosen not need to take the screws right out(as ppl have been known to drop these..lol).........lift out the air filter......you will notice only half of it gets used..look down to the front and bottom of the airbox..you will see a a pipe inlet....the top can be unclipped and taken out.......by doing this it makes the airflow better.hope this helps.if not go to the proper how2 lol
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    This is for a 1.9cdti but the air box should be the same on the 2.0t
    clicky linky
    North London
    thanks
    Regular Member rickyroo's Avatar
    shropshire
    I've removed the cyclinder shaped outlet that goes inside the airbox in the top half just buy cutting it off as level as I could and sanding down the rough edges at an angle, loads more air feed. noticed difference. if you put the airbox back together and look inside the box where the engine feed would go you will be able to see the whole top of the filter instead of a pathetic little opening.
    Sep 2009
    Slovenia
    sorry to bring this up but I manage to do this airbox mod on my 2.0T (+ standard panel filter) and I think I noticed good response at lower revs and also I think after 100+ miles my consumption is better (before it was 30mpg now 32mpg). Is this just me or am I driving like a grandma now?
    What was your experience with airbox mod on 2.0T engine about fuel economy?
    Regular Member TonyJames's Avatar
    Sep 2009
    northants
    I agree mine is better since i done it 2 weeks ago
    Although it could be that the ecu has learned my driving style,i'm doing about 100 miles a day at moment all dual carriageway and i pay for my own petrol so i just cruise at 70 am getting about 34 mpg
    Regular Member Marcosuk's Avatar
    Fife
    I've now started to notice a slight improvement in MPG, but ive just replaced the fuel filter & plugs so might might help 2...lol..
    I put a pick up of the 2 parts removed from the airbox
    http://www.vectra-c.com/forum/showthread.php?t=102745
