Likes Likes:  1
Results 1 to 10 of 17
Thread: Vectra air blowers not blowing hard enough?
    Nov 2015
    Default Vectra air blowers not blowing hard enough?
    The air/heat blowers for my 05' vectra aren't very powerful.. Their strength on 4 (full) is barely what 1 (minimum) is on other cars... I've had the a/c looked at and that's now running properly just lack of air flow... The only thing that's missing is the air recirculation pump.. But the mechanic's I've spoken too can't say whether fitting one will solve the issue.. And since I never use the recirculation function, I don't want to pay out to sort this, if it doesn't fit the flow issue... So any idea's that'll help fix this would be greatly appreciated.. :-) it's cold when driving home from work when it's minus 2 outside... Even with the heaters on full!!!
    Sent from my D6603 using Tapatalk
    Regional Organiser - South something area HarrysDad's Avatar
    Jul 2014
    Camberley, Surrey
    95 Post(s)
    Vehicle : Insignia A
    Trim : Sri
    Engine : A20NHT
    Mileage : 54323
    Whats the pollen filter condition like? Don't know if this would impede air flow but worth a look at it.
    Check HERE for upcoming meets/events
    Nov 2012
    cumbernauld
    It's probably a bit of loose ducting air recirculation will blow air on and off. You just need to follow the ducting from the motor. It's just an actuator in the car that does the air recirculation. Take the ducting under the motor off put it on 4 see if the air pressure is coming out there if it us start looking for disconnected ducting to vents
    Sent from my GT-I9505 using Tapatalk
    Ashington, Northumberland
    I'm with Harrysdad. A choked pollen filter will most definitely cause this. Easiest and cheapest fix too if it is that. When I bought my daughter her Astra, the heater blower was like a negligible breeze. Took the pollen filter out, and I have never seen one as blocked and black as this one was. Heater blower works as it should now.
    Jul 2014
    Camberley, Surrey
    95 Post(s)
    Trim : Sri
    Engine : A20NHT
    Mileage : 54323
    Quote Originally Posted by GARY3306 View Post
    My Dads focus st2 was the same, really bad air flow even on the highest setting that's why I mentioned it. I changed his pollen filter and it turned out to be an aftermarket one that had folded inside the housing partially blocking it. Was a pain in the butt to change as the glove box had to come out along with the fuse panel and lots of bolts as its hidden behind the center console in the dash on a focus.
    I know all about Focus pollen filters. What a pain
    Jul 2014
    Camberley, Surrey
    95 Post(s)
    Trim : Sri
    Engine : A20NHT
    Mileage : 54323
    Haha, would love to meet the guy who thought "I know, lets put a serviceable part where Jo Public cant get to it without being a contortionist and disassembling half there car"
    Full Member Allydfr's Avatar
    Mar 2012
    N.I
    Vehicle : Sri
    Engine : 1.8vvt
    Mine was the same when i bought it! As said i changed the pollen filter in mine and was shocked at the difference it made. Deffinitely worth a bash first
    Nov 2015
    Will definitely check out the ducting for it.. And let you know.. Cheers guys.. :-)
    Jan 2021
    Turkey
    Vehicle : Opel Vectra 2011
    Trim : Vectra 2011
    Engine : 1.3
    Year : 2021
    I think there will be a problem with the pollen filter. It would be best to take the air blower to the nearest repair shop.
  1. Blowers not blowing hot on vectra CDTI
    By roosie in forum General Motoring Chat
    Last Post: 22nd February 2014, 13:37
  2. Blowers blowing very little air!
    By elfrider in forum Bodywork & Interior
    Last Post: 12th January 2014, 21:21
  3. Blowers not blowing hot
    By john506 in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2013, 21:04
  4. hard blowing noise from vec c v6 cdti v6
    By v6 sri diesel in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2011, 00:04
  5. blowers and ac blowing hot air
    By Baz4u2me in forum Vectra C / Signum Troubleshooting
    Last Post: 27th January 2010, 15:17
vectra c blower not powerful
vectra c blower not powerful site:www.vectra-c.com
