Thread: Insignia Rear Camera
    Regular Member Kev_G's Avatar
    Jul 2009
    C:\Uk\Chester_North West
    Default Insignia Rear Camera
    Has anyone fitted a rear view camera to the number plate light yet to see the rear of the car as I was looking to do it to ours as I can never see the rear end or how far back I can go
    Nov 2015
    somerset
    Vehicle : Insignia
    Trim : CDTI
    Engine : 2ltr
    Did you find an answer to what you needed?
    I have recently fitted a rear view camera to my Insignia
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    222 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    You would certainly need a low level mounted camera for a parking aid IMO.
    Bumper or number plate positioning would probably give the best rear view.
    Let's remember it's a "parking aid", rather than a "dash cam".
    HTH
    Woody's Vx Ice Addons UK/Eire Distributor of the Comfort Unit and Video Accessories from www.PepaS.cz Designed to enhance your Headunit & Display these add in Additional Data and Reversing Camera & Media. NOW INCLUDES FULL Vxr/OPC NEEDLE SWEEP & LIGHTS Also CD70 Aux In & 3 Line Display Updates.
    Nov 2015
    somerset
    Vehicle : Insignia
    Trim : CDTI
    Engine : 2ltr
    Quote Originally Posted by Woody View Post
    HTH
    I fitted mine at the top of my number plate - from there the wire was easy to feed into the boot to connect to the reversing lamp wire (green/white) and feed the video wire to the front cabin.
    The view is perfect and I can get within 6" of any obstruction/object/car behind.
    South London
    The camera is only part of the installation.
    You will also need something to display the output from the camera on, with a suitable input to accept the camera signal.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    This is the setup on the facelift insignia, perfectly centred but discreet
    Nov 2015
    somerset
    Vehicle : Insignia
    Trim : CDTI
    Engine : 2ltr
    I positioned my slightly different style camera in the same place.
    From there it was easy to feed the wires down the back of the bumper and then through the grommet into the boot - the grommet is the one used for the rear light wiring.
    I connected the camera power to the green and white reversing light wire found in the opening on the left where the rear fuse box is, and fed the video wire into the front of the car under the carpet.
    I then fed the video wire up the side pillar by pulling off the door rubber, and using a feed rod fed it through to come out in front of the rear view mirror.
    The monitor is built in to the rear view mirror (which also has a built in front camera and records front an back views constantly - it also has bluetooth hands free and sat nav built in).
    In the photo of the mirror you can see the reversing view in which is a wheel located under the window shown on the mirror.
    Sep 2019
    Barnstaple
    Trim : SRI
    Engine : CDI
    Year : 2000
    Old thread but I'm about to mount a reversing camera just above the number plate on my Insignia estate and was wondering if it will effect the MOT?
    The camera is the same as the one shown in this thread.
    12 Post(s)
    My Astra-J has gone through 3 MOTs with a number plate camera.
    Light output is less than the other numberplate light, but no one has commented on it yet. 4th MOT next week. Finger crossed.
    Looks something like this.
    https://www.ebay.co.uk/itm/for-Vauxh...n/192612797537
    Sep 2019
    Barnstaple
    Trim : SRI
    Engine : CDI
    Year : 2000
    Thanks for the reply, sorry its like this one https://www.vectra-c.com/forum/attac...4&d=1448883206
  1. Rear View Camera fitted to rear screen?
    By Mark2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2013, 16:52
  2. Replies: 28
    Last Post: 22nd January 2011, 12:01
  3. rear camera
    By chris1804 in forum Electrical & ICE (including SatNav)
    Last Post: 29th May 2010, 17:57
  4. rear view camera
    Last Post: 19th March 2010, 09:15
  5. Insignia 2010 - No Camera Option?
    By VXR_DV in forum Insignia car chat
    Last Post: 31st July 2009, 16:51
https:www.vectra-c.comforumshowthread.php221380-Insignia-Rear-Camera&goto=newpost
vectra c install reverse camera www.vectra-c.com
how to install reversing cam on my insigna face lift
insignia rear view camera
is the wiring there for insignia reverse camera
insigia facelift rear camera
reversing camera on insignia
