Thread: Wobbly Bolts
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Default Wobbly Bolts
    Will a set of wobbly bolts adjust to pcd of 114?
    Regular Member 3.2_V6_VXR's Avatar
    S.Wales, Nr Swansea
    cant be done mate 2mm max, i use these wobbly bolts on my audi wheels
    Jul 2006
    Northampton
    Trim : Sri
    So its a custom adaptor then. Thanks mate, anybody know where i can get one of these?
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    the thinest adapter i have found is 20mm, which will reduce the offset of the wheels. (i.e, if u wanted the wheels to stick out the same as "normal" vaux wheels, the wheels u get would have to have an offset of 55mm.).
    also im not sure if an adapter has been made for a 5x114 to 5x110 change. usuall patterns are 5x120 or 5x130.
    contact http://www.performancealloys.com/ they are top company when it comes to wheels.
    Jul 2006
    Northampton
    Trim : Sri
    Just looked and its not on there. It will definatly need to be custom made. Mmm... pricey
  1. Wobbly bolts
    By mark1319 in forum Styling
    Last Post: 30th July 2007, 15:40
  2. Wobbly bolts. Where??
    By freks in forum Suspension, Wheels & Brakes
    Last Post: 1st April 2007, 06:40
  3. Wobbly Bolts
    By Danwells72 in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2007, 22:32
  4. Wobbly Bolts for wrong PCD ???
    By Bainie in forum Suspension, Wheels & Brakes
    Last Post: 9th July 2005, 19:40
